1996 Explorer Power window problem
Old 04-26-2007, 11:11 AM
00GT's Avatar
00GT
00GT is offline
Having a problem with the power windows. I can control all the windows from the driver pad but not from the other switch's on each of the doors. Could the window lock switch be bad in the driver door? Confused....
Thanks
Old 04-27-2007, 05:49 AM
marragtop's Avatar
marragtop
marragtop is offline
CHeck the connections on the windows lock switch. Also, try rocking in back and forth a couple of times to see if there is any improvement.
Old 04-27-2007, 11:34 AM
00GT's Avatar
00GT
00GT is offline
Heres something weird... When i try to roll down the passenger window from the driver controls and at the same time from the passenger side window controls the passenger window stops until i release the pass. window switch. There must be some sort of power going to the pass side switch to interrupt it when i roll it down from the driver side.
Thanks
bigtexan99
1999 to 2016 Super Duty
09-13-2017 08:46 AM
boggin79ford
WTB - Parts & other
01-11-2017 03:25 PM
renegade_75
06-18-2016 08:43 AM
projump
2004 - 2008 F150
07-18-2015 07:38 PM
gabes
05-08-2015 09:12 AM
Quick Reply: 1996 Explorer Power window problem
