Towing with a 1981 F100 4.9?
As long as you have the load balanced and secured in the bed of the truck and or trailer, it should be a walk in the park for the ol "Tower of Power". What trans and rear end gears are you running? If it's an auto it may be a bit sluggish, with a manual you can better harness the engines power by selecting whichever gear handles the load best. I have towed in excess of 10k lbs with my 84 F150 with the 300 six/ 4 speed. Getting the load rolling is no problem... it's getting it to stop in an emergency situation that fills my under pants. I wouldn't be afraid to tow 1800 lbs with the truck you have, just take it slow and easy... don't be in a rush.
Originally Posted by Sycostang67
Not hard at all. Most people will steer you away from a 302, as there isn't much difference and the 300 makes a bit more torque. The 351W is the better way to go for the V8 swap, makes the task more worthwhile.
Back to my original question, would you guys have any worries of towing 1800 lbs for a 6 hour trip each way, driving at 60-70 mph?
Obviously, it depends on the condition of the truck/motor, but assuming it's in decent shape...
Also, anything else I should look at? I might be buying a guy's truck tonight.
Originally Posted by Redneck1465
I see no problem what so ever especially if you decide to change over to the 351W. Thats what I have and I have pulled way more than that for way longer than that with no problems.
I'm starting to have too many "project" vehicles
You won't even feel that with anything over 3.50 gears.
Back in the day before the PSD, would drag 15k+ with a 300, M5OD, 1356, 4.10s in a dana 80 dually axle, 88 F-350 frame, '91 cab and a whole lotta love.
Thing was a mutt, and never won a speed race on the hills, needed low range to back the trailer on a grade, and wasn't purdy, but never failed to start and tug whatever strapped to it.
Adrianspeeder
Adrianspeeder
You can get performance out of the 300 just as easily as anything else. If your looking to pick up a few more ponies and ft lbs, it can be done relatively inexpensive. You can get an adapter plate and install a 2bbl Motorcraft carb from a 302. Install a set of EFI exhaust manifolds with a Walker downpipe, 2.5" pipe with no cats and decent flowing muffler. Also maybe go to an open element air cleaner, and a hotter ignition coil. If you are running an automatic, 3.55 or 3.73 gears would be ideal with around a 29-30" tall tire.
i had an 81f100 short bed with 3 on the tree and 2.47 highway gears in the rearend. i put a clifford 4 bbl intake with carter 650, efi exhaust manifolds into a 3 inch banks muffler exiting before the rear wheel. it sounded great and pulled ok for the tranny and rear i had. i hauled a 16 ft. lowboy trailer with 2 big rolls of hay on it at 75 mph. wasn't that bad taking off either.
MelvilArnt
06-10-2017 07:03 PM
rwrobinson
17
03-06-2013 01:33 PM
grw800
09-09-2010 07:00 PM
dirtballer
21
05-20-2009 12:45 PM
