Illinois Chapter Join Chapter Leader: wpnaes
yellowed headlights
Old 05-01-2007, 09:50 AM
Hood20's Avatar
Hood20
Hood20 is offline
yellowed headlights
The headlights on my 98 Explorer are turning yellow. What's the best way to clean these so they're at least clean enough for the lamp to shine through w/o being dimmed by the yellow plastic? Thanks!!!
Old 05-01-2007, 10:33 AM
Zip's Avatar
Zip
Zip is offline
White toothpaste will take some of it off. Also some fine sandpaper I used 1000 then 1500 then some polishing compound to get out the fine scratches. I think you can also get kits somewhere for this as well.
Old 05-01-2007, 03:14 PM
Hood20's Avatar
Hood20
Hood20 is offline
I saw a polishing kit at Walmart yesterday. It was from www.myheadlight.com. It cost $20. Has anyone used it? Does it work as it claims? Thanks for the toothpaste idea. I'm a bit skiddish on the sandpaper though. Maybe a last resort.
Old 05-01-2007, 03:17 PM
Zip's Avatar
Zip
Zip is offline
I used the sand paper. Lots of water and started with the 1000 grit, then the 1500 wet, followed by the polishing compound.
Old 05-01-2007, 03:27 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Meguiars PlastX takes off the yellow fading.
StangMan
Ford Truck Parts for Sale
05-28-2014 02:00 AM
Whitey Ford
02-22-2012 08:42 PM
93f250tn
44
02-15-2011 05:16 PM
Hood20
New Member Introductions
04-30-2007 10:01 PM
Gouge
10-20-2002 12:04 AM
Quick Reply: yellowed headlights
