Towing capacity?
You first need to know what axle gearing your '89 302-powered Bronco has. My '90 XLT has factory 4.10:1 gears,a EFI302,and a AOD trans. According to the 1990 Ford Bronco Brochure ,Ford gave this combination a maximum trailer towing capacity of 7,800 lbs..The 1989 Bronco brochure lists the same rating. If you have 3.55:1 gears the rating is just under 7,000 lbs..You should buy a couple of Bronco brochures...they are fun to read.You can get some at places like Spring Carlilse,and online. As for a '89 owner's manual,ask your local Ford dealership's parts department.I bought one for a '96 Bronco. I think they got it from Helm Publishers. Hope this helps ya!
