not starting when warm
I just had a crate motor put in my truck. 88 f250 460. it runs great. starts fine when its cold, but when its warm it will start, sputter, than stall, or turn over slow like a dead battery. I am not getting any codes.
Is this from the new motor still being tight, or am I missing some thing.
Thanks
Bob
Thanks
Bob
With your volt meter hooked up 1 lead on the positive bat post the other on the positive bat connection, when you crank your engine over you want to see close to 0 volts no more than .3 volts if this is good move down the line to the next connection,
You will do this on both pos and neg bat cables. It is best to check it when the problem is there. Any excessive voltage that show up on your meter is voltage the starter is not getting ( drop). You also want to watch for swelled cables, cuts in insulation can allow corrision to start working turning the wires green and starting the resistance problem. A common place for this to happen is between the bat connection and the first 3 or 4" of the cable Good luck
You will do this on both pos and neg bat cables. It is best to check it when the problem is there. Any excessive voltage that show up on your meter is voltage the starter is not getting ( drop). You also want to watch for swelled cables, cuts in insulation can allow corrision to start working turning the wires green and starting the resistance problem. A common place for this to happen is between the bat connection and the first 3 or 4" of the cable, Good luck
I also got to thinking about how the truck would start warm, then sputter and stall. It could be possible that you have two problems that seem to happen at the same time. The turning over slow could be the starter, and your start then stall could possibly be the ignition module, since they are a known problem in these trucks. The ignition module would not affect your ability to crank, but would cause the truck to run poorly and then stall. Unfortunately I think I am grasping at straws here since the most common symptom of a poor ignition module is that they fail start completely when warm and work when cold, not start and then die. Good luck
VRC9170
08-02-2011 06:04 AM
Bob O GomA
1983 - 2012 Ranger & B-Series
09-20-2004 08:14 PM
unioncreek
01-26-2002 10:05 AM
