setting up a dedicated tow vehicle
I am looking for help with ideas of a perfect Bronco as a tow vehicle,, I am starting with a 1988 with a 302, I have read an article on a brake upgrade using F-350 parts and it sounds good !what gears should I run if the boat and traler wt' is 5500 lbs.
and any/all suggestions will be welcome.
thanks Bo
thanks Bo
First you need to find out what axle ratios your Bronco came with from the factory. Ford listed the EFI302/AOD/4.10:1 gearing combination as having a 7,800 lb. towing capacity. If your Bronco came with the 3.55:1 gears,it will have around a 6,800 lb. rating. If you have a 5-speed manual tranny-Ford didn't really supply true figures.Why? To save on warranty repairs to worn out clutches,and the like. You might try upgrading your exhaust system to add power for towing duty.A K&N air filter will also help your 302.If your Bronco came from the factory with a towing package,it should have an external oil cooler. If it doesn't,I'd suggest you buy an aftermarket one. Most auto parts stores should have(or can get) what you need. A HD frame-mounted hitch you'll need also. For extreme towing'I'd suggest the steeper 4.10:1 gearing...if your truck doesn't have them,already. You'll lose mpg,but it'll pull without fuss. Good luck.
stugpanzer
11-28-2009 08:33 AM
ghcoe
26
04-01-2008 09:24 PM
