Best Thermostat Choice? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-24-2007, 02:08 PM
The Grinch The Grinch is offline
The Grinch is starting off with a positive reputation.
Question Best Thermostat Choice?
I currently have the coolant drained to replace the oil cooler, and figure I should replace the thermostat as I can see the gauge changing temp while I drive based on speed and grade (unloaded truck). What is the best choice for temp rating on a replacement thermostat? I have heard I believe a 204 or 205 degree was best. Any input - and should the thermostat be moving like that? I can understand the temp moving when loaded, but an empty truck? Seems to me the thermostat replacement is due.
Old 04-24-2007, 02:57 PM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
Try this one:
http://www.dieselsite.com/index.asp?...ROD&ProdID=188
It's at the bottom of the page.
Good addition for a little extra HP. Diesels like to run a bit hot.
I'll bet your radiator is on it way out if the temps are rising at e-way speeds. My temps stay about the same empty or loaded once it gets up to temp. I don't have the 203 therm....yet.
Old 04-24-2007, 03:43 PM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
The water pump design changed in late 95 (depending on plant build location some 96's have the old style). If you have the old style water pump the long stem thermostat will not fit, and you will have to go with the short stem. I can only find the short stem in 195 degrees. So I just get them from NAPA.
Old 04-24-2007, 03:50 PM
My truck was built in Oct of 1994. My water pump was changed in 2000. It is still the same design as original. So that would be the short stem, correct? So the radiator is heading south? The temps change while driving due to being plugged up? I thought I have been good at the coolant changes and keeping up with the additives.
Old 04-24-2007, 05:24 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
The last napa short stem for my old 95 was a 203 stat. I don't ahve the part number handy but I kow for sure that 2 years ago when i got it was a 203.
Old 04-24-2007, 05:58 PM
ltfox's Avatar
ltfox ltfox is offline
ltfox is starting off with a positive reputation.
Quote:
My 94 take the short stem stat and all i could find for it was a 205* stat.
Old 04-24-2007, 06:04 PM
tjbeggs's Avatar
maybe thats what mine was too. I don't know! I do know it was either a 203 or 205.
Old 04-24-2007, 06:06 PM
tjbeggs's Avatar
here ya go. here's a link to napa online for a 95 PSD thermostat
http://www.napaonline.com/masterpage...d=5&SubCatId=1
Old 04-24-2007, 08:32 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD DAVID'S97F250HD is offline
DAVID'S97F250HD is starting off with a positive reputation.
Try washing out the rad, remove the grill and wash straight in so not to bend the fins, if you have an A/C condensor thats the one that will mostly be plugged. Found them to get plugged with bugs and dirt. Had a mustang that did this untill the rad got washed out and solved the issue. Its cheap to do and worth a try.
Old 04-25-2007, 10:38 AM
Thanks. I will give it a wash before I do anything else. Definitely the least trouble and cost!
240 thermostat john jamieson Ford Inline Six, 200, 250, 4.9L / 300 2 12-01-2016 07:52 AM
Need advice on coolant flush with thermostat and coolant filter install Danner717 6.0L Power Stroke Diesel 11 01-13-2016 02:52 AM
1994 ford low coolant temp spyder314 1987 - 1996 F150 & Larger F-Series Trucks 15 08-15-2007 10:53 PM
Thermostat Stuck? 86 F-250 w/ 351W HO Coneynew 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 01-08-2007 01:09 AM
Thermostat choice 86 f150 fordfinatic Cooling, Heating, Ventilation & A/C 2 11-16-2005 09:32 PM
Tags
1997, 2006, 205, 350, 95, automotive, best, correct, ford, napa, powerstroke, psd, replace, thermostat, thromostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
