Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-23-2007, 07:06 PM
Frank Stahl Frank Stahl is offline
Garage is empty, add now
Frank Stahl is starting off with a positive reputation.
running SVO need new injectors ?
I need new injectors in my truck 2000 7.3 Ford,
I run the Grease car system, using straight veggie oil.
Is there a special injector, or what do you guys suggest.
Thanks Frank
  #2 (permalink)
Old 04-24-2007, 03:30 PM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
most people running SVO, WVO, BIO whatever are using there stock injectors. i don't know whats the best, but they are using the stock ones because thats what they have. You could just replace with new stockers or reman ones, but i would look into some performance injectors because my philosophy always is if you are going to fix it might aswell get more power while your spending the time/money .
__________________
2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
  #3 (permalink)
Old 04-24-2007, 03:54 PM
bio-d bio-d is offline
bio-d is starting off with a positive reputation.
If you're getting your svo up to 176*, then its the same viscosity as diesel at minus 10*F. This is from a Frybird chart referenced in Ray Holan's "Sliding Home", an exellent svo guide. I was advised by Craig Reece of Plantdrive to have my injectors set at the upper end of their opening pressure due to this lower viscosity. I have an 87 6.9 turbo; not sure about your year/ engine.I've been wondering about the DPS stage I injectors. I'm mostly interested in MPG than Power, though, and haven't talked to them about it.
Mike
  #4 (permalink)
Old 04-25-2007, 07:41 AM
KansasDiesel KansasDiesel is offline
KansasDiesel is starting off with a positive reputation.
I have over 21,000 miles on WVO using the Vegistroke type system, I changed my injectors before the conversion just because I like performance. but stock injectors will work just fine. Why are your injectors trash? Make sure you are getting all the water out of your oil and filtering down to 2 microns and you shouldn't have any injector problems. I find it when people are not filtering and dewatering then they tend to have injector problems. Beans Diesel Performance have delt with people using WVO.
My Stage 1 injectors cost me less then to replace with new stock injectors. Check out Beans Diesel Performence.
  #5 (permalink)
Old 04-27-2007, 08:01 PM
I have 35000 miles running SVO, and 132000 miles on my truck.
I guess they just wear out after awhile?
Frank
  #6 (permalink)
Old 04-28-2007, 09:34 AM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
You should not have that much wear on those injectors. I had over 400k on my injectors before I changed them out. They are laying on the garage floor with most of the injector holes coked up or plugged up with carbon goo. Ive run the wmo oil which was a big mistake and filtered not heated oil, second mistake. I think you ought to get a second opinion on the injectors. It could be any number of things giving you a misfire on the injectors. You might start with the bottom link on my sig from Chris G. He has a product that has given my truck longer life and may free up any buildup in your oil or injection system.
__________________
585,000+ miles on original engine. Goldie 00 F-350
  #7 (permalink)
Frank, its lubrication specialties.
__________________
Tags
69, 73, ford, injectors, oil, running, straight, svo, truck, vegetable, veggie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
