how do i convert 2wd ranger to 4wd? - Ford Truck Enthusiasts Forums
Old 04-23-2007, 06:52 PM
PISTON PISTON is offline
PISTON is starting off with a positive reputation.
i have a 2wd 90' ford ranger xlt extended cab. i would like to convert it to 4wd. what does this mean i am going to have to get into. i heard i could do it farely easily, just by swapping out the front end with a 4x4's front end. is it a simple project, or a pain in the ***? and will it work? if and when i do this i want to get a good lift and put some 35" or so tires on it.
Old 04-24-2007, 01:29 PM
kjett's Avatar
kjett kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
It all depends on how good your fabricating and welding skills are. You should be able to get all the parts from a 4x4 Ranger and drop it all in, but if you are going to do it, might as well find a solid front from an 66-77 Bronco. The earlier D44's are drum brake, but that is easy to convert, so look for a later 73-77 axle as it is a ball joint, disk brake axle and the 760x joints will fit. The problem after that is the front will be a 5x5.5 lug pattern and the rear will be a 5x4.5 pattern. You will need to either get an aftermarket set of axles or change the whole rear. To do the SAS swap, you will more than likely need at least 4", if not 6", of lift to fit some 35's.
After you figure the axle parts out, you will need to go into the transmission/tranfer case swap and get a set of driveshafts made. A stock set will be a good starting point, but with any lift, they will need to be lengthened, so might as well start with new ones.
All in all, it will be costly, so if you are not too attached to the truck, it me be more cost effective to just find a 4x4 truck and build from there.
Old 04-24-2007, 02:24 PM
Help I M Stuck Help I M Stuck is offline
Help I M Stuck is starting off with a positive reputation.
having done this once before..it's much more easier to go find a 4x4 truck and build on that. Too many hours and $$ to do it the other way around.
Old 04-24-2007, 05:11 PM
thanx, i think ill just wait till after i get back from iraq, then ill have money to play with, and ill just buy an old jeep cherokee. ive always wanted a jeep cherokee to mess around with. lol, besides, having 2 trucks will be better than one i guess.
Old 08-13-2011, 10:15 PM
Ranger II Ranger II is offline
Ranger II is starting off with a positive reputation.
Hi all,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
New to this forum, <o></o>
<o></o>
The conversion was not that challenging. You have to exchange the engine saddle, welding/cutting/re-bolting. My donor vehicle was a bronco II, so the rear axle hangers have to be shimmed out ˝” on each side. The Bronco II axle, a trac-lok is 1” wider than the Ranger?” Everything else went fine. Nice truck. Pic’s if requested, and the rest of the unused parts are on Cragslist. <o></o>
<o></o>
Nice forum<o></o>
Old 08-13-2011, 10:23 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
I wonder if the OP ever made it home from Iraq....
4 years ago
Old 08-14-2011, 08:24 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
Quote:
i sure hope so, we have lost way too many people over in that craphole of a country
Old 08-14-2011, 09:50 AM
77mud's Avatar
77mud 77mud is offline
77mud has a good reputation on FTE.77mud has a good reputation on FTE.77mud has a good reputation on FTE.
Quote:
that we have i still say we nuke them
ps is that a bot or something??
Old 08-14-2011, 12:43 PM
i ain't rite
Quote:
i agree 1 gazillion percent
huh??
wat chew talkin bout willis???
Old 08-14-2011, 02:07 PM
77mud's Avatar
That rangerII is he a bot/spam or something?
and im glad someone agrees with me on nuking them asses
Old 08-14-2011, 02:23 PM
i ain't rite
oh ok. nah, it reads like that because he typed it out in ms office and posted it without editing out the office addons.
Old 08-14-2011, 03:39 PM
77mud's Avatar
oh okay gotcha
Old 08-14-2011, 06:53 PM
Yea, just cut in' paste, sorry. Just thought I would post my experience here in doing the conversion. I did the conversion after reading about it here. So I thought I would add my 2c.<O</O
Bronco II with <10K miles on a complete re-built drive train “then wife rolled it ” Found a 2wd Ranger “cheap” and looks good in and out, so I decided to go for it.
Old 08-14-2011, 07:35 PM
77mud's Avatar
nice point in case why my gf dont drive my truck
Old 08-20-2011, 12:25 AM
dondonman dondonman is offline
dondonman is starting off with a positive reputation.
i would like to know this to cuz i have a 1982 f150 2wd in good shape and a 83 f150 4wd but the
4wd's frame has canser so can just pull the drive train and swop them bolth have 300 inline 6 bolth have 4 speed tranny just got to cut a hole for 4wd stick bolth even have same rearend only diff betwin the 2 is 1 year and 2wd vs 4wd
Converting from 4wd to 2wd. Vegasw0lf 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-25-2015 10:41 PM
'01 Ranger converting to 4 wd Pablo-UA Ranger & B-Series 7 07-10-2010 04:21 AM
Can 2001 ranger 2wd rims fit a 4wd 88 ranger maryland ranger Ranger & B-Series 0 01-06-2010 07:25 PM
lowering a 1978 f250 capnmorgking 1973 - 1979 F-100 & Larger F-Series Trucks 0 10-14-2008 09:16 PM
converting 94 ranger 2wd to 4wd tulenut Ranger & B-Series 4 12-23-2003 12:57 AM
Tags
1997, 2wd, 4wd, 4x4, axle, change, cherokee, conversion, convert, converting, drive, ford, front, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
