TAB, TAD, Thermactor diagram
I have an 88f250 5.5L. I am trying to figure out how to hook up my TAD and TAB. I think that I need to connect to the two vacuum solenoids over by the coil. Could someone out there trace back the vacuum lines from those two solenoids and let me know where they plug into? I think one is for the bypass and one is for the diverter. I don't know which is which, nor do I know which port on the solenoids go to the manifold and which go to the diverter/bypass.
thanks
thanks
Originally Posted by dagray3
subford,
sorry, that was supposed to be 5.8L.
what's the calibration number? Where do I find that?
I will check autozone and see what they have
This is also the only number that I can use to post the right vacuum diagram for your truck as there are 10 calibration numbers for the 88 Light truck with a 5.8L.
The number should be on your door post or under the hood.
It would something like:
8-64H-R10
also, this diagram shows that my TAD and TAB solenoids are connected to a vacuum reservoir (I think that's what vreser means). Is that the big plastic box over on the passenger side of the engine compartment?
And, man vac is manifold vacuum?
Here is a key to the above diagram:
AIR BPV = AIR ByPass Valve
CPRV = Canister PuRge Valve
CARBON CAN = CARBON CANister
EVR = Egr solenoid Vacuum Regulator valve assembly
EGR = Exhaust Gas Recirculation valve
SOLV = SOLenoid vacuum Valve assembly
MAP = Manifold Absolute Pressure sensor
VRESER = Vacuum RESERvoir
MAN VAC = MANifold VACuum
DIV = air DIverter Valve
FPR = Fuel Pressure Regulator
PCV = Positive Crankcase ventilation Valve
TAB = Thermactor Air Bypass vacuum solenoid valve
TAD = Thermactor Air Diverter vacuum solenoid valve
timbersteel
10-31-2021 01:23 PM
JF492
02-05-2017 06:10 PM
capriceragtop
10-03-2013 05:51 PM
