waterless car wash?
Wayne, that's the polisher that I have. It works terrific. For more involved work I have a 9" Makita orbital buffer with different pads. I have found with the P/C polisher that the 6 1/2" Meguiars burgundy colored foam pad be the most versatile. They make different textured pads for different objectives, like the compounds. Can't help ya with a store, I get my stuff from a local detail supply shop. My Son is a pro detailer.
on
Originally Posted by ALBUQ F-1
.....Mr. Clean car wash system ....... 2nd neat thing about it is that the sprayer has a "final rinse" setting where water pressure forces the water thru a resin deionizer/filter. The water that comes out is pure enough that it doesn't need to be toweled off -- no spotting!
Originally Posted by StevenK
I've been wondering about the Mr Clean system. So it really does dry spotless with no toweling?
I think if you used a garden sprayer with some (dishwasher) "Jet Dry" in it, you would get the same results.
or use a nozzle on the hose that has a soft, fine "rainshower or mist" setting. Hold it so it sprays at a flat angle to the panel and the water will sheet off rather than forming beads. I then go over it with a California squeegee, and can finish dry a whole car with one handtowel sized microfiber towel.
