You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Depends on your processor size.
For small stuff, just use a plastic drum.. I use a 15 gallon poly drum and just dump KOH in through a wide mouth funnel.. I then use a piece of 3/4 pvc pipe to mix it all up.
The whole process takes about 5 minutes. You must monitor heat generation and on a hot summer day, you might have to slow down the mixing to let some heat dissipate. I don't have any fume control and since I have an open hole I'm mixing through, I do this outside.
I'm moving up to a 200 gallon processor that will require something different.. I'm thinking of pump mixing and a stainless tank to take the heat.
Murphy, you should be carefull doing that in plastic, and with PVC.
Methanol will eat it up.
__________________
Talyn (AKA: der Schafen Führer)
1994 F250 XLT 4x4 Standard Cab - T-444E Direct Injection Turbo Diesel, 5 SPD M/T Z/F S5-420, Rosewood 160cc Stage 1's, PHP Tuner, 6637, Short Throw Shift Kit, Valair Kevlar/Ceramic, 140V IDM, T-500, 285/75/16 Cooper Discoverer ATR. Steyr C9-A1. You can get more with a kind word and a 2x4 than you can with just a kind word.
That information is incorrect.
1. My methanol comes in plastic 55 gallon drums.
2. Methanol and PVC work just fine together.. Rating is "EXCELLENT"
Not sure what you are talking about.
I use methanol with PVC frequently.. never a problem or even a hint of one.. (I use Sch80 pvc.. the dark grey stuff)
The only thing you need to worry about when mixing methanol and lye in a plastic container is heat. The process of mixing the two creates lots of heat so if you have high titrating oil, you may want to mix only half of your lye at a time..
