brake questions... - Ford Truck Enthusiasts Forums
brake questions...
Old 04-23-2007, 12:07 AM
Coley Coley is offline
Coley is starting off with a positive reputation.
brake questions...
I did a search but never came up with an answer...so...can I use a disc/drum master cylinder with drum/drum brakes?My original MC is leaking...instead of buying another one I thought I would buy a bracket and update to a dual cylinder MC...and what is the absolute best MC to use with a non-power drum/drum set(using the original pedal,etc.)Thanks!
Old 04-23-2007, 12:27 AM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
I`d like to know too, mine is leaking and now is a good time to switch over.
Old 04-23-2007, 12:45 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Off the top of my head, early Mustang used drum/drum with a dual res. Check with Sacramento Vintage Ford - they sell the kit.
Old 04-23-2007, 12:52 AM
Fomoko1's Avatar
Sacramento Vintage Ford sell a kit to mount the mc in the stock location?
If so this is good news.
Old 04-23-2007, 01:01 AM
yeah...hope this works out...
Old 04-23-2007, 10:47 AM
Yes, they show a variety of setups -
With power booster for drum/drum; disk/drum; disk/disk
They also have brackets for a variety of applications. Honestly, I can't tell from the descriptions if they have something for non-power, drum/drum, dual res systems.
I can't see why a dual res for disk/drum wouldn't work. Disks require more pressure and volume to stop.
I'm sure a call to SVF would help sort it out. They have a tech line (916) 853 2244
Old 04-23-2007, 06:38 PM
49fordpickumup's Avatar
49fordpickumup 49fordpickumup is offline
49fordpickumup is gaining momentum as a positive member of FTE.
Brakes
I just looked at the articles section and they showed a mod to upgrade the 69-74 Ford E-series vans drum/drum to disc. The project was on a -72 ford E300. I would go to my auto parts dealer, ask to look at a 69-74 Ford E- series van m/c, look at spec's.. Go to a weekend auto rally and talk to owners, etc. Have a great day, chuck
Old 04-24-2007, 08:30 AM
I'm trying to keep the drum/drum setup if possible...I think the late 60s Mustang MC will work,but I'm not sure...guess I better call SVF...
Old 04-24-2007, 09:56 AM
Brakes
Thats what I was saying ,the 69-74 is drum/drum. I'm sure there are others but this is the first I found. Have a great day,chuck
Old 04-27-2007, 07:19 AM
Chuck,do you think the E-series MC will fit on that bracket?
Old 04-27-2007, 07:21 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Drum-drum dual masters: Ford passenger cars 1967/
Most of the dual Ford master cylinders are about the same length, the boosters are not.
F100's from 1968 had dual master cylinder drum-drum brakes into the early 1980's. Many of the F250/350's from 1968 had drum-drum dual masters till 1973. Discs were first offered as an option in 1968 on F250/350's, but prolly only 25% came with discs, most were drum.
Old 04-27-2007, 09:12 AM
Brake m/c
Coley, I don't have any knowledge about brackets for m/c. The info was from FTE threads and articles at the top of the page. Most after marker auto parts people will help if you take your bracket. Some have counter help knowledgable like numberdummy. I see he has some good info also. It seems like the 60's was a period of change in the auto industry to start the use of disc brakes. I hope I helped,chuck
Old 04-28-2007, 08:51 AM
Thanks,Chuck!
Old 04-28-2007, 10:43 AM
4tl8ford's Avatar
4tl8ford 4tl8ford is online now
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Sac Vintage Ford
PN# 14078 Master Cyl Mount - use 67-72 Mustang dual reservoir master cyl with 1" bore.
PN# 14064 Master Cyl Adaptor - angles down for additional clearence - same as above.
PN# 12001 Master Cyl - Mustang - 67-72 dual chamber
Old 04-29-2007, 09:00 AM
So#14078 will enable me to use the Mustang MC on my 54 F-100?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
