Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation & A/C
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Cooling, Heating, Ventilation & A/C SPONSORED BY:
Click Here
  #1 (permalink)
Old 04-22-2007, 08:21 PM
89ranger2.9 89ranger2.9 is offline
Garage is empty, add now
89ranger2.9 is starting off with a positive reputation.
How do you bleed air out of the cooling system?
I am about to flush my coolant on my 2.9 Ranger and I want to make sure there isn't any air in there. Is there anything special I have to do? I remember reading on here sometime back and some guy said to just fill the radiator and overflow up all the way and it after a couple of running cycles it should purge any air...is this true? Is there a special bleeder port on the radiator or anything? Many thanks...
  #2 (permalink)
Old 04-22-2007, 08:39 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
1998 Ford F-250
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
If you can, park the vehicle on a incline. The idea is get the radiator as high as possible to let the air escape. You can also fill the radiator and run it a few times as mentioned. Just don't fill it and not check it after the first couple of runs.
__________________
Dan
1998 F250 LD 4X4
2004 Explorer EB 4X4
2006 KLR 685
Tags
2003, 29, 88, air, bleed, bleeding, coolant, cooling, explorer, f150, f250, ford, purge, ranger, remove, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
