wheel inserts (hubcaps) - Ford Truck Enthusiasts Forums
Old 04-22-2007, 02:43 PM
golddirt golddirt is offline
golddirt is starting off with a positive reputation.
mine keep popping off and i have to find some. any tip's on keeping them from popping off. 99 150 cab 1/2 5.4 2 wheel
Old 04-22-2007, 03:25 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
There used to be a thread about this....I looked and I cant find it. Maybe someone will be along to answer for ya.
Have you tried squeezing the rings closed a little?
Old 04-22-2007, 03:27 PM
yes tried that thanks
Old 05-01-2007, 06:36 PM
any help out there guy's?
Old 08-05-2007, 04:42 PM
cant believe know one has no info on these.
Old 08-05-2007, 11:13 PM
ATC Crazy's Avatar
Old 08-06-2007, 04:45 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I would put a little high temp (red) gasket sealer inside the clips that go over the lugnuts. This may help keep them on.
Old 08-06-2007, 05:17 AM
fdrf150 fdrf150 is offline
fdrf150 is starting off with a positive reputation.
Smile
Maybe try replacing the lug nuts? Are they worn down from being taken off a lot? Just a thought.....
Old 08-06-2007, 04:41 PM
thanks i'll think the lugs are worn down.
Clutch line popping off slave cylinder templars Ranger & B-Series 3 07-07-2015 08:35 AM
Drivers side Intercooler boot keep popping off Crazyotto1 1999 - 2003 7.3L Power Stroke Diesel 11 11-13-2014 04:55 AM
popping exhaust riverguideguy 1973 - 1979 F-100 & Larger F-Series Trucks 17 11-30-2013 01:38 PM
cruise control horn pad pops fuses? 86f150step 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-23-2013 07:21 PM
Wheel hub caps keep falling off! 2K3 Mach Ranger & B-Series 3 07-07-2008 06:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
