2001 F150 A/C not cold
I bought a reacharge kit with the gauge and when i put it on the fitting, it shoots up and says it doesn't need charging....
however, even on today's 70* day, it doesn't blow very cold, it's cool, but not cold.
any ideas or do i need to have a mechanic "purge" and recharge the system?
Originally Posted by Ultramagdan
Is the compressor kicking on and how often?
I checked fuse #13, A/C clutch, it's fine.
I see that there are several relays and a diode, but even after reading the Haynes, I'm clueless....
I see that #204 is the A/C Clutch relay and #502 is the diode for the same...
my fiance tells me the a/c hasn't worked for a while, before it was put in storage for 6 months, then driven for 3, then storage again for 4.
Originally Posted by bustech81
have you checked for power at the clutch. I would not go off of the cheesy guage that comes on those recharge kits to tell you pressure. get yourself a real set of guages. also what is the ambient temp?
does that make a difference?
when i run the defrost, the A/C should kick on also, shouldn't it? so the ambient temp could be 10 degrees and it should kick on and off???
Ambeint temp does play a factor in weather or not your clutch should kick in or not. R134a static pressure stays fairly constant with temp. So if its 10 degress out, the static pressure in your system is close to 10 lbs. Most cycling switches open at approx 12lbs.So in a fully charged system, at 70 degress, you will have 70.7 lbs. of static pressure.
Originally Posted by ford390gashog
a/c will cycle in defrost to remove humidity from the air.
I almost think the dealer could diagnose just as fast, if not faster, than the local mechanic, they both charge $68/hour.
its not an expensive fix if you do it. i spent 33.00 on the kit and 2 hours of time. but first i would jump the clutch to straight 12v and see if it then kicks in , if so it is one of the pressure sensors thats bad.
how do i do this?
