Stock 360/390 Cam vs. Crane 343901 - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 05-03-2007, 03:27 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Yes, use the Crane lifters and springs.
  #62
Old 05-05-2007, 02:37 AM
"Beemer Nut" "Beemer Nut" is offline
"Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE.
Check each individual assembled valve with retainer for your seated spring height then shim to Crane's spring specs. Don't forget your seals.
  #63
Old 06-08-2014, 04:44 AM
skrudumra's Avatar
skrudumra skrudumra is offline
skrudumra is starting off with a positive reputation.
some questions answered, some not
I read the entire thread and found that I still have a question for someone that may know. I have a '70 F250 with a 360 that I'm pretty bent on keeping a 360 (366 only if needs be). I'm ditching the two barrel in favor of a Carter AFB 600 on top of a 1964 390PI intake. I'm having the heads done including hardened exhaust seats, new seals, shaved (yes I know to have the intake cut to match) to achieve 10:1 compression, port matched, bowls blended. I'll use the 343902 C/L with new springs and timing set (adjustable double roller). Not sure about which brand of headers yet but thinking of Sanderson flowing through 2.5" duals through Flowmaster 50's. Does anyone have any performance numbers for a set up like this? Obviously it's a truck that'll be used as a truck and not a dragster so I'm trying to get as much torque from the short stroke engine as I can.
360 cam/ timing questions cowboyfordlord FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 03-21-2013 10:45 PM
crane 343901 or 34341 ? redneck hillbilly FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 25 12-16-2008 08:10 AM
desktop dyno request 7FORD2 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 42 03-11-2007 09:36 PM
Crane 134052 JonnyB69 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 07-05-2006 09:32 PM
Comp cam vs. Crane freejay FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 15 08-29-2003 09:57 PM
Tags
343901, 343902, 360, 390, big, cam, camshaft, crane, crane343901, duration, factory, fe, ford, lift, stock, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
