Stock 360/390 Cam vs. Crane 343901 - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 04-26-2007, 03:29 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Yes, they run them toward the top of the plunger travel to limit how far the lifters can pump up. Really any lifter can be run like that. But dont over do it, because it will limit how far the lifter can adjust for normal valvetrain wear, and the plunger would eventually break the clip. Like I said, 3/4 to 1 turn seems to be the magic amount, and some guys directly measure it.
I've heard of Chevy guys only going 1/4 turn though (although their valvetrain is different)... crazy Chevy guys!
  #47
Old 04-26-2007, 03:31 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Quote:
Originally Posted by rusty70f100
Lifters also do something called "bleed down" over time. What this does, is oil eventually escapes the lifter through the check ball / disc. This also helps with lifter pump up, as it will allow an over extended lifter to come back down to proper adjustment quicker. I think this is what they do with "anti-pump up" lifters. They just bleed back down quicker. They may also have a lighter internal spring, although I'm not entirely sure on that one.
From memory of 17 years ago, the only difference in the anti-pumpup lifters I used was a groove cut into the seat for the disc check-valve. This would allow oil to get past much faster.
Every once in a while, I'd startup my 390, and it would rap-rap on a few lifters. But that was only after a few months of sitting. It wouldn't do that every day.
They DID make more noise at idle though. But I have/had double valve springs that were like 200lbs or more range for on-seat pressure. My machinst said to make it bullet proof because I had a Triumph TR7 at the time that I loved to take to 7500RPMs
As I remember, the anti-pumpup lifters were also rated for a much higher valve spring pressure than stock lifters. The stockers were at risk for failing under that much pressure. But I'm not sure on that one.
I would suspect, with the bleed-down being FASTER than a regular lifter, that the internal spring would be HEAVIER to try to counteract the bleed-down.
Anti-pumpup lifters (as I remember) were intended to keep them from pumping up if you got valve float and then slamming the valve into the piston.
I still have all 16 lifters in my 390 ... if I didn't plan on doing something with it, I'd take a lifter apart and take pics... maybe
  #48
Old 04-26-2007, 06:49 PM
I need to make a correction on how lifters work. The oil comes in the side, and the plunger is in two parts. That way they only need one check valve.
  #49
Old 05-01-2007, 04:33 PM
1975Ford's Avatar
1975Ford 1975Ford is offline
1975Ford is gaining momentum as a positive member of FTE.1975Ford is gaining momentum as a positive member of FTE.
Kurt, how's the low end torque and fuel economy for the 343941 crane cam? How's the 343941 cam for towing?
  #50
Old 05-01-2007, 05:37 PM
Low end torque is great; You'd think you're driving a stocker. Fuel economy is also good. One trip on the highway I got 17mpg.
Crane also lists the cam for towing, so it'd probably be good there too.
Good all-around cam. Here's what Crane has to say about it:
"GOOD IDLE, DAILY USAGE AND OFF ROAD, TOWING, PERFORMANCE AND FUEL EFFICIENCY, 2600-3000 CRUISE RPM, 8.75 TO 10.75 COMPRESSION RATIO ADVISED. BASIC RPM 2000-5000"
  #51
Old 05-01-2007, 09:17 PM
Krewat's Avatar
The 941 is about the same cam as I had in my 390 - Wolverine Blue Racer, 292/292adv, 230/230@.050", .554/.554" lift. Not exactly, but somewhat close
Advanced 4 degrees, it pulled the 5500lbs '74 highboy around like it was nothing. 2 tons in the bed, still pulled like nothing. Didn't even need 1st (435NP) to move 4000lbs in the bed from a dead stop, and no more than 1500RPMs. w/33" tires and 4.10 gears.
Idle was quite lopey...
Compression was in the 10.5-11 range.
Got 15MPG on a 400 mile trip.
  #52
Old 05-01-2007, 09:38 PM
Your cam looks a bit more wild than the 941.
941 specs:
Adv. duration: 272/284
.050" duration: 216/228
Lift: .533"/.563"
Idle isn't real lopey, but that depends in a huge way on the amount of initial timing advance. If you set it to the 6-8 degrees they came with stock, then yeah, it'll lope. If you give it what it wants, it'll idle like a stocker. Smooth as glass. There is a technique that works quite well, but I guess it's not PC on this board.
  #53
Old 05-01-2007, 10:19 PM
Krewat's Avatar
PC for whom? No censorship or anything else going on here... post away!
Yeah, it was basically the upper limit for hydraulics...
My only point being even lopey sticks can get great low-end with a 390 stroke...
  #54
Old 05-02-2007, 11:30 AM
PC for the "purists" who think it should only be set up the way Ford did it.
If I posted it I can guarantee at least 2 members here would jump all over me for it, and may even leave bad rep. So if anyone really wants to hear how to make it idle smooth with a big cam send me a PM.
  #55
Old 05-02-2007, 11:40 AM
Krewat's Avatar
OH NO! Not the big bad "inverted vacuum advance" ?
AHHHGG!!!!!!!
  #56
Old 05-02-2007, 02:41 PM
snortf100's Avatar
snortf100 snortf100 is offline
snortf100 is starting off with a positive reputation.
What are your thoughts on this Cam?
Edelbrock Performer-Plus Camshaft
Ford FE 352-428
Duration Advertised 272 Intake/282 Exhaust
Duration @ .050'' 194 Intake/204 Exhaust
Lift @ Valve .460'' Intake/.480'' Exhaust
Lift @ Cam .265'' Intake/.280'' Exhaust
Lobe Separation Angle 110
Intake Centerline 105
Intake Timing @ .050" Open 8 ATDC
Close 22 ABDC
Exhaust Timing @ .050" Open 37 BBDC
Close 13 BTDC
  #57
Old 05-02-2007, 03:05 PM
Crap. Compare the duration figures to the 343941 I mentioned above.
  #58
Old 05-02-2007, 08:58 PM
"Beemer Nut" "Beemer Nut" is offline
"Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE.
Almost the same specs as a worn out CJ cam.
270/290, 194/204 @ .050, .481/.490, 46* lap.
  #59
Old 05-03-2007, 10:15 AM
snortf100's Avatar
941 specs:
Lift: .533"/.563"
If you were buying this cam would you include lifters and new springs from Crane also?
  #60
Old 05-03-2007, 10:42 AM
1975Ford's Avatar
Quote:
Originally Posted by dbossman
at survivalmotorsports.com..... He offers a cam that is one notch above the 390GT/428CJ cam. Its 204/214 duration at .050 and 484/510 lift.
I am using one in my 428 with factory style adjustable valvetrain. Its certainly a mild cam, but I really like it. It runs real strong.
SurvivThis is a good cam too.
Yes, go with Crane everything (cam, lifter, springs, retainers, etc..) if you this route, that what I did.
Remember more lift more wear.
JMO, I like to keep the lift at above the 0.500 mark and below the 0.560 mark.
I running the Crane 343902 cam/ lifter setup.
360 cam/ timing questions cowboyfordlord FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 03-21-2013 10:45 PM
crane 343901 or 34341 ? redneck hillbilly FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 25 12-16-2008 08:10 AM
desktop dyno request 7FORD2 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 42 03-11-2007 09:36 PM
Crane 134052 JonnyB69 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 07-05-2006 09:32 PM
Comp cam vs. Crane freejay FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 15 08-29-2003 09:57 PM
Tags
343901, 343902, 360, 390, big, cam, camshaft, crane, crane343901, duration, factory, fe, ford, lift, stock, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
