Anyone Tell Me Where This Vacuum Line Connects (2004 5.4 3V)?
Old 04-21-2007, 10:18 PM
DRM2004's Avatar
DRM2004
DRM2004 is offline
Where Does This Vacuum Line Connect (2004 5.4 3V)?
I noticed this vacuum connection hanging loose. I've looked and looked and can not see where it connects. Thought maybe you guys can help.
I've attached some pictures. One from my truck showing the actual vacuum line. The other two from my manual showing what vacuum line I'm talking about.
My truck is running fine. No issues, but this is really bugging me that I can't find where this is supposed to connect.
Though maybe someone would take a minute and look on there truck and let me know where this vacuum line connects.
Thanks in advance.
Old 04-21-2007, 10:47 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
It looks like a factory "stopper" plug? So maybe it lays loose?
Old 04-21-2007, 11:13 PM
FTE Trigger
I just went out and snapped a few shots of a plug I knew I had... you can find them here...
http://s102.photobucket.com/albums/m...1nsc/Vac_plug/
(4.6L '05 '150 XL)
Old 04-22-2007, 12:32 AM
DRM2004's Avatar
DRM2004
DRM2004 is offline
99Trigger3_0,
I appreciate the reply.
Well, I guess its supposed to be loose...
Any difference between the 4.6L vs 5.4L on exactly where the vacuum line is routed?
Old 04-22-2007, 06:41 AM
wlgoble's Avatar
wlgoble
wlgoble is offline
Vac Plug
I ve an 04xlt also. I have the exact same line and it is pluged off just like yours. Glad you posted though, Ive been wondering about mine. I know mine came from the factory like this and you having the same, just confirms that. Mine just lays loose. The line is sorta molded to certian shape like its meant to be routed somewhere. But it just lays there. I guess we shouldnt worry about it. I think its probably for an option that our trucks dont have.
wlgoble
2004 SCAB XLT
Old 04-22-2007, 06:56 AM
wlgoble's Avatar
wlgoble
wlgoble is offline
vac line possibilty
Hey mabe its to add vac for trailer brakes. When I get time I will try to chase it to the other end. Maybe it ends under the dash and plugs off there. Dont know, just guessing.
wlgoble
04 SCAB XLT
Old 04-22-2007, 10:25 AM
ohboy44's Avatar
ohboy44
ohboy44 is offline
Are all your trucks 2 wheel drive?
That vacuum line is for the vacuum operated hubs on 4x4s.
Old 04-22-2007, 11:44 AM
DRM2004's Avatar
DRM2004
DRM2004 is offline
Ohboy44,
Yes, my truck is a 2wd.
Thanks for the information on the vacuum line.
My Haynes manual talked about disconnecting this vaccum line during disassebly of the intake manifold...it said "if applicable"....this makes since now that I know its for the vacuum operated hubs on 4x4's.
Old 04-22-2007, 01:48 PM
wlgoble's Avatar
wlgoble
wlgoble is offline
vac
yes mine is 4x2 also !!!!
Old 04-22-2007, 09:10 PM
96f150's Avatar
96f150
96f150 is offline
Yep, thats what the plug is for...That is where the vacumn lines would hook up to for the IWE
zonker
112
06-25-2017 05:20 AM
MTP55
13
12-11-2016 03:05 PM
VaSheriff
07-13-2010 11:27 PM
FILTHY
06-16-2009 10:18 PM
Sawbones25
03-05-2008 10:36 PM
Quick Reply: Anyone Tell Me Where This Vacuum Line Connects (2004 5.4 3V)?
