Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
99 lightning specs
Old 04-21-2007, 07:55 PM
wreck fixer's Avatar
wreck fixer
wreck fixer is offline
99 lightning specs
I just bought a 99 lightning that needs a front end, but the only one I can find close to me is from a 2002. Will this work or am I going to have trouble with the coolers and mechanicals? I am not an expert on these trucks and any input would be greatly appreciated. Thanks in advance.
Old 04-22-2007, 03:20 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
What part of the front end of your '99 is being replaced? Part of the front clip, a front hub assembly, a ball joint or two, the upper grille? The lower grille?
Please be specific. There were a few minor changes between the '99/'00 and the '01+ years. Most notably, and actually (now that I think about it) the only things changed were 12mm lugs vs 14mm lugs, the addition of Bilstein shocks, and the front facia, causing the fog lights to be mounted differently.
Stewart
Edit: The crank pulley attaches slightly differently in the '01+ models too. And the S/C bolt pattern to the midplate is different. But I'm sure the s/c bolt pattern isn't a concern for you.
Old 04-22-2007, 06:24 AM
wreck fixer
The only part I'm concerned with is the radiator, air charge cooler hoses, and the bolt on stuff right out front. I was concerned maybe some of the coolant plumbing was changed. Thanks for the info, thats why I always keep an eye on this forum.
Old 04-22-2007, 11:50 AM
Stewart_H's Avatar
Stewart_H
Nah, except for the items I mentioned (for example the fog light mounts) all that stuff is exactly the same from year to year.
Stewart
f100guy
12-17-2010 05:47 PM
tomshelby
Electrical Systems/Wiring
06-13-2007 10:45 PM
OD1010
03-28-2004 01:13 PM
xpac
10-20-2003 09:11 AM
99SVT
09-30-2003 09:32 AM
Quick Reply: 99 lightning specs
