Inner fender removal
.......about 10 minutes. There are 4-5 screws around the fenders edge, 1 screw bottom of fender under door edge, 3-4 christmas trees at the radiator support and I think 1 christmas tree center top of inner fender. I think you can get to them all without removing the flare screws. I just had my right one off to replace a fender. I try to photo everything but you got me on this one.
Originally Posted by ncranchero
Some inner fenders are a real pain to get out but these are surprisingly easy. BTW, really nice truck you have! Looks like a twin to my 1998. I just put the updated nose on mine.
What was all involved in doing the updated nose on your truck? Cost and parts needed? I might do that down the road if money permits.
No. Here's the list that was posted previously on FTE.
‘97-‘98 to ’99-up F150 Front End Swap
The whole front will bolt on but none of the 97-98 parts will work on the 99+ or vice versa. Good sized part lists but a very easy job.
------------------------Normal F-150 Front End Upgrade ----------------
(1) 1999-2004H Grille Shell
(1) 1999-2004H Left Grille Shell black plastic deflector
(1) 1999-2004H Right Grille Shell black plastic deflector
(1) 1999-2004H Bumper
(1) 1999-2004H Left Bumper Brace
(1) 1999-2004H Right Bumper Brace
(1) 1999-2004H Left Bumper-to-Frame Mounting Bracket
(1) 1999-2004H Right Bumper-to-Frame Mounting Bracket
(1) 1999-2004H Bumper Top-Pad
(1) 1999-2004H Bumper 2WD Bottom Air Dam
---------------------or--------------------
(1) 1999-2004H Bumper 4WD Bottom Air Dam w/ Fog Lights
You can reuse the plastic deflectors but they need to be trimmed.
2-4 hrs depending on how much help you've got. Pull the bumpers off first, then the grille shell. You'll need to take the corner lights out to get to 2 screws behind them. IF you have an early production 97 (6/96 or earlier), the lights are mounted different. Just pull the 2 metal tabs behind the header panel. The head and corner light will come out in 1 piece. On the later version, there is 1 screw on top of the corner light. There are also 2 metal clips on the bottom of the shell.
LARIAT 85
09-16-2015 08:12 PM
