OEM battery a little weak for the V10?
I had my first hiccup with my truck and it is my own doing.
The battery conked out after only 28 months but I did put a high powered security system on this truck soon after I got it. I love the Vipor system but the fact that it is constantly transmitting to the remote and this works up to a mile away means a trickle drain to the battery is happening all the time.
Also the blue LED is very bright and lights up the cab at night.
Any way , now the good part, the OEM cheapo is only a 650 cold cranking amp battery. I bought a new 900 Cold cranking amp battery from Costco and WHAM, the truck is starting faster than it ever did. Big difference.
I have heard many of the guys saying their 3 valves like a lttle extra crank and mine sure did. Now you barely hear the starter and she's running, more like all my old Ford gassers. The battery reference chart shows all SD gassers have the same battery fronm the factory so it is possible we get the same battery as the 5.4 guys.
One last comment, the OEM battery is just done in. It won't take a charge and the red dot is showing. The acid levels in all 6 cells was right up .
And my big Babe, never embarassed the Ford name by dieing on the road. No, she refused to start on the morning of my road trip with my fiver.
I hit the starter and tick....tick.... tick.... Opened the hood and spotted the red eye on the battery. Good deal, she could have died on the BC Ferry and POed five hundred other drivers. Man I love this truck.
On Edit, The Costco battery is a perfect fit and uses the lower wedge clamp like the OEM. I had it changed out in under 5 minutes.
This battery has a 100 month warranty so if I get 48 months out of it I will be lucky. Also, If my truck had been driven every day, the OEM battery may have lived longer but the truck can sit for up to 4 days at a time.
Anyway, the way she starts now is worth the 71 bucks I paid for the new battery.
Funny you should mention the tick.... tick..... tick.... Last winter at about zero degrees (or less) I had that happen, fortunately in my driveway, so I threw a battery charger on it. Initially it drew 3 - 4 amps, but within just a few minutes this dropped to less than one amp. So I tried to start it but still no deal.
The dealer concluded that I probably left the lights on; he charged the battery and the problem hasn't recurred over the last 3 or so months.
I thought these batteries were supposed to have some kind of isolated reserve capability that would still allow you to start once if the lights are left on, except that my 2005 obviously doesn't have that capability.
But then too, I wonder why my charger couldn't stuff any juice into the battery. I.e., its like the charger was seeing 14 volts so it had nothing to do....
In my case though the eye was not red. Thanks though for the CostCo recommendation. If the problem recurrs I'll just go with the 900 amp model as you suggest. Thanks.
If there's a "manual" setting, or a 10 amp setting, you might want to try that, keeping an eye on the battery during charging. Don't run it at 10amps for more than an hour or so without checking on it. Dangerous in an enclosed area
yep don how correect about the factory low amp batterys.
but also the lead plates also start to break down, letting very small flakes of lead build up in the bottom till they short out the plates.
they also sulfate after a while and in plain words. just drop dead and say they have 12 volts but sure don't have the amps any more. how they sulfate don't ask me maybe some super brain knows and can explain to this worn out dead beat just back from HI.
on
750 CCA battery...
Originally Posted by krewat
My original battery is a 750 CCA. For a 2001.
Any idea how I ended up with a 750? Not that I mind!
In any case, it still going strong after nearly 5 years with some sub-zero winters behind it and plenty of towing time.
