F150 Seat Replacement - Ford Truck Enthusiasts Forums
Old 04-20-2007, 04:50 PM
Niteshift5 Niteshift5 is offline
Niteshift5 is starting off with a positive reputation.
Question F150 Seat Replacement
Hi Everyone,
I'm new to this forum and have found alot of great information here.
I just purchased a 1993 F150 2WD Reg Cab. It is an XL model and is in great shape.
I want to replace the bench seat with one from an XLT because I want to have the armrest.
Will the seat from a newer model fit right in or will modifications be needed?
Thanx in advance for any information on this.
Have a Great Day!
Old 04-20-2007, 06:10 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
If the seat is from the same body style (80-96 7 ) The floors are same and will bolt up
Any from 92 up should match your interior great . Good luck
Old 04-22-2007, 02:34 PM
Acemandb Acemandb is offline
Acemandb is starting off with a positive reputation.
If you go newer that 1996 take careful measurements because the seats are wider and you will probably interfere with your door handles.
Finding seat in good condition is the trick. I adapted power leather buckets out of a 2004 Jeep Grand Cherokee and dropped a F250 console between them.
Did it all with an angle grinder, drill & hand tools by fabricating adaptor plates out of 1/4" aluminium plate. It can be done without welding.
Measure, measure and measure again.
Old 04-22-2007, 02:37 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
I put the buckets and console from an '86 camaro into an '80 malibu that way. That was no easy feat. I even made the shifter from the camaro work in the 'bu. Luckily the 2004r and 700r4 use the same shift lever and I was able to swap them. It can be done.
Old 04-23-2007, 04:00 AM
kulprit's Avatar
kulprit kulprit is offline
kulprit is starting off with a positive reputation.
I replaced my old bench with these, they have a good selection, prices aren't bad and are very comfy also gives you some extra storage as well
http://www.atthemart.com/acb/showprod.cfm?&DID=10&CATID=13&ObjectGroup_ID=29
Old 04-27-2007, 08:31 PM
Thanx for the info guys. New seats are nice but way out of my price range. I guess I'll have to cruise the junk yards more often to find something that will bolt right in.
Old 11-10-2010, 11:06 AM
3meansforever 3meansforever is offline
3meansforever is starting off with a positive reputation.
Nightshift5---
Did you replace that bench seat? I am looking for that seat in tan, if you still have it, I would love to talk to you about it.
david.peyton@firstmansfield.com
King Ranch Seat Swap? Windy Isle 1997 - 2003 F150 2 10-28-2016 11:30 AM
Bench to bucket seats in '99 F150 Sport BGF 1997 - 2003 F150 2 10-21-2016 10:02 PM
Which seat will work Brich3838 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 03-20-2016 08:48 AM
single cab ford bench seat swap to bucket seats makattack 1987 - 1996 F150 & Larger F-Series Trucks 2 06-24-2015 10:58 AM
Replacement Seats vs. Seat Covers CPT P 1987 - 1996 F150 & Larger F-Series Trucks 11 11-12-2013 10:49 AM
Tags
1993, 1996, 2002, 93, bench, f150, ford, interior, leather, older, repair, replacement, seat, seating, seats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
