300rpm?
Old 04-19-2007, 05:44 PM
Xyzzy's Avatar
Xyzzy
Xyzzy is offline
300rpm?
I probably screwed the math up, but I was trying to figure out what my 4.2L (auto) 3.55 F150 would turn if it had a 4.10 rear axle.
Right now I get 1850RPM at 65MPH.
My math tells me I'd get 2150RPM at 65MPH with the 4.10.
Questions:
  • Is my math right? If not, how do I calculate RPM/ratio differences?
  • Does 300RPM make that much of a difference? My 4.2L doesn't even wake up until way past 2150RPM.
  • How can I figure what 3rd gear is? When I watch the digital tach it looks like it jumps 800RPM or so if I hit the OD off button.
  • Does the transmission still lock out the torque converter in 3rd?
So far I'm very happy with my 07 4.2L.
Old 04-23-2007, 09:01 PM
Xyzzy's Avatar
Xyzzy
Xyzzy is offline
Bump?
I'm especially curious about the torque converter lockout in third gear. I sure wish I could find the "specs" to the transmission. Shift points, lockouts, ratios and stuff like that.
Old 04-24-2007, 09:22 AM
BrianA's Avatar
BrianA
BrianA is offline
I get 287 rpm difference. Pretty close to the 300 rpm you came up with.
I think 300 rpm might be noticeable, but not extremely significant when driving down the freeway. Likely more noticeable when starting off / pulling a load.
I do believe the transmission will lock / unlock the torque converter in 3rd gear.
I think I have all the info you wanted. I just have to see if I can find it ????
Thanks and sorry for the delay. Life has been a wee bit hectic lately.
Old 04-24-2007, 09:27 AM
Xyzzy's Avatar
Xyzzy
Xyzzy is offline
I'm used to car, motorcycle and even R/C car/truck magazines publishing torque/horsepower dyno charts. It sure would be interesting to see the charts for the various Ford truck engines. Just giving peak values is meaningless, IMO.
Boss08v10
Modular V10 (6.8l)
05-14-2012 09:45 PM
FlatoutKrazy
01-31-2012 05:27 PM
greystreak92
1978 - 1996 Big Bronco
16
01-15-2011 01:44 PM
fordeverpower
02-01-2006 08:48 PM
brider
16
05-08-2005 05:55 AM
Quick Reply: 300rpm?
