siphoning gas - Ford Truck Enthusiasts Forums
siphoning gas
Old 04-19-2007, 06:21 PM
axp117crow axp117crow is offline
axp117crow is starting off with a positive reputation.
Exclamation siphoning gas
ok so i need some help fast if any of you can. my finaces 96 cavalier broke down and it has 3/4 of a tank of gas in it. my truck runs great but is almost of out gas.
no i'm out of money till i get my check tomorrow afternoon and need to get to work in the moring. how do i siphon the gas out of her car? i think it has one of those anti siphon things cuz when i put the hose in i'm not touching gas, but it is hitting something. any ideas?
i think i'm gonna have to ask someone for a couple bucks but i really hate doin that. can someone help me please??
Old 04-19-2007, 06:55 PM
Americanmadeford's Avatar
Americanmadeford Americanmadeford is offline
Americanmadeford is starting off with a positive reputation.
Disconnect a fuel line, (at the fuel filter for example) put a bucket under the line, and turn the key so the fuel pump engages. Seems to me this would work (in theory). SOmeone correct me if Im wrong.
Old 04-19-2007, 07:09 PM
the battery and alternator are absolutely no good at all, when i tryed turnin the car over nothing came on at all, so i don't think the fuel pump would kick on either
Old 04-19-2007, 09:40 PM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
park your truck in front of the car. Jump her battery, not to start it but to just get the fuel pump to come on. Pump the fuel into a suitable gas container and then into your truck.
Old 04-20-2007, 12:53 AM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
Try cutting the siphon hose at an angle; sometimes that works.
Steve
Old 04-20-2007, 01:09 AM
JOHNAXIS JOHNAXIS is offline
JOHNAXIS is starting off with a positive reputation.
try using a 5' 1/4" vac line works for me not fast but if u are not stealing it you should be fine at about 5gal in 30min
Old 04-20-2007, 01:31 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Never siphon gas with your mouth, if that's what you were trying to do. I'm sure a lot of people have done it, but they shouldn't.
Old 04-20-2007, 09:49 AM
rsylvstr rsylvstr is offline
rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.
Quote:
It's Ok if you don't smoke afterwards
Old 04-20-2007, 01:49 PM
CO River Rat
If you use clear tubing, there's less chance of getting a mouthful of gas.
Steve
Old 04-21-2007, 12:06 AM
stm250 stm250 is offline
stm250 is starting off with a positive reputation.
My father in law always used an ice pick or small screw driver to poke a hole in the thing and pull her out always worked for us
Old 04-21-2007, 02:34 AM
the gas is not the prob it is the vapors from the gas. but in the small amount u get you would have to do it 5-10 times a day my father is a doctor and that is what he told me and some guys from his work were saying so i would have to take there word on it.
Old 04-22-2007, 10:02 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
Save the mint for after you start your siphon.
'03 E-350 Motorhome Fuel draining help Redneck with Tech 1968-2013 Full Size Vans 8 07-17-2014 07:54 AM
Siphoning Gas 79F-350 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-12-2011 02:00 AM
Unsuccessful in SIPHON attempt neilc88 Excursion - King of SUVs 14 02-13-2009 10:15 PM
siphoning gas from front tank to rear tank FordF350Baby 1987 - 1996 F150 & Larger F-Series Trucks 3 05-01-2008 10:52 PM
Gas siphoning deterrents RichardW 1987 - 1996 F150 & Larger F-Series Trucks 22 05-21-2007 10:33 PM
Tags
1999, 99, explorer, f150, f250, ford, fuel, gas, havasu, lake, ny, siphon, siphoning, syphon, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
