Intake/ exhaust valve stem seals different or the same???
1977 thru 1979 351M ~ 400 valve seals
Originally Posted by ladiabla74
Well, I went to autozone and advance auto parts and both had different part numbers for intake and exhaust. HHMMMMM??????
16-D7AZ-6571-A .. Valve Seal ~ USE before Serial Number EE0,001
8-D7AZ-6571-A .. Valve Seal = Intake ONLY ~ USE after Serial Number EE0,001
8-D9OZ-6571-A .. Valve Seal = Exhaust ONLY ~ USE after Serial Number EE0,001
The serial number in this case refers to the VIN number's last 6 digits.
No Ford truck ever had a 351C engine.
>>>16-D0AZ-6571-A .. Valve Seals for a FORD PASSENGER CAR 351C 1970/73 <<<
Only the later 351M/400's engines (cars & trucks) have different seals.
When I asked for the seals I asked for a 351c in a '73 mustang and still got different part numbers for intake and exhaust.
kilog55,
The engine is smoking on the driver's side only. Plugs 7 and 8 are wet with oil. 8 more that 7 (way more, it is actually soaked). U got any ideas? I was told it could be the a broken ring or too much play on the valve stem. This are band new rebuilt heads with brass guides. The engine only has about 50 miles on it. It was working fine until the day I was gona get it inspected.
you could pull the heads off again and pull the springs again, and see if there is any movement in the valves. kind of a PITA but thats the only way to tell if it is the valve guides.
or do a leakdown on the compression check. i think you squirt some oil in the spark plug hole screw in the checker and watch it for loss of pressure but i have never done it so i may be wrong here
couttolenc
04-06-2015 08:48 PM
whd507
09-12-2005 05:43 AM
David10
07-05-2003 11:08 PM
