Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-19-2007, 11:56 AM
ErnieX is starting off with a positive reputation.
4L head gasket leak?
Hey guys,
I have a 95 Exp, 4L pushrod. #4 cylinder is dead. I have spark and gas. I hooked up air hose to #4 plug hole and under pressure it forces water up slowly out of the radiator fill hole. Can this be anything other than a bad head gasket or cracked head? Want to make sure before I start tearing into it.
Thanks in advance for any help.
EE
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-19-2007, 08:45 PM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
Most likely a cracked head...these motors aren't as famous for it as the 2.9, but still have a tendancy to crack the haeds. Not much else it could be other than the that or the head gasket. Did you get it hot?
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 04-20-2007, 12:05 AM
Rockledge's Avatar
Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.
Quote:
I agree. There is a small chance that the lower intake gasket has failed between the #4 cylinder and the coolant port on that corner. Either way though, you're gonna have to take the top end apart.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #4 (permalink)
Old 05-02-2007, 02:11 PM
Thank for the replys. It hasn't been overheated that I'm aware of. Guess I'll tear into it and hope for the best.
EE
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
