428 vs. 390
428 vs. 390
i have never worked on a 428, i always seem to end up with 360 or 390, i was wondering what advatages the 428 can offer vs. the 390. i have been junk yard hopping a lot lately and thoght if i came across one i might get it. What vehicles would likely have one and how can i identify it as a 428.
on
1 Post
Buyer Beware!!! I have had 4- 428's in the last 4 years....and the machine shop screwed up one to the point of NO repair.. the next 2 had cracks in the blocks that werent diclosed at time of purchase... and now I finnally have a good one..
Also watch out for over bored Late block 390's that are being passed off as 428's !
RJ
RJ
I came across a company today that is making a conversion kit to add cross bolted mains to any FE.
I also came across a main girdle on ebay that ties the main caps to the base skirt of the block. I liked the looks of this.
Also came across a set of Harland Sharp roller rockers for the FE on ebay. I wish I could afford them.
Originally Posted by dffay
Ford put 428's in the heaviest of their cars I think so they could get some faster revs to push those road pigs along better. Look at big Ford sedans for 428's.
428 intro'd in '66 in the 7 Litre Galaxie.
http://www.wctatel.com/web/crye/7l-bkgnd.htm
It was more "square" than the big bore shorter stroke 427, and had hydraulic lifters and a much milder tune, which made it nicer to drive in a "family" type car. However, when applied to the Mustangs in CJ and SCJ trim, much of the 427s goodies like heads and a couple of other items came into play, and it made just about as much power as a 427.
So, how to id a car with one: Look for "7 Litre" badges or "428" badges, and a big empty space under the hood.
Check the forums, the best bet is to make a 410 out of your 390 with an after market stroker crank.
https://www.ford-trucks.com/forums/2...questions.html
I had a chance to buy a '66 7 Litre convertible. $1200. Well, too much rust and I didn't have a place to work on it. I see they only made 2300 or so. Oh well....
Don't forget to check the 66 and later Tbirds for 428's. They used the std 428 version. You can also look for later service blocks.
www.428cobrajet.com check the block section under component ID. You see the differences between the std and CJ blocks. Also some ID tips.
G.
G.
