A bunch of good manuals, is the place to start. As far as codes,a jumper wire is all you need and the manuals will tell you the rest. If you can get an original ford manual, go to ebay, it will go along way to answering your questions.There is only one computer you can look at. There are code readers you can buy, that make it easier to see the codes. You should have an OBD1 system and the readers are fairly cheap( $25) .
stractor
