You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Some good info there. A lot of things to think about when working on a good source of oil. Thanks.
__________________
Eric 1999 F350 4x4 Super Duty, Crew Cab Long Bed,7.3 Diesel, 6 speed, 4'' Diamond Eye exhaust, 4040 Aeroturbine, Dipricol Optix-boost and pyrometer, AIH delete, Hutch and harpoon, Tuff Country Add a Leaf
Democracy is two wolves and a lamb voting on what to have for dinner-liberty is a well armed lamb contesting the vote" Thomas Jefferson
Murph,
I think your information on the gas trash pump is a little skewed. Ive been using one for about a year now and I believe if you have a sizeable amount of oil to collect its the fastest and neatest way to go.
First almost all trash pumps are self priming, I havent had to prime my pump since the first initial prime. I have pumped oil when the temperatures were in the single digits. (I do use a heating element attached to an extension cord in the winter to make it go faster) but I have pumped some thick paste. Also you dont have to worry about the pump clogging it pumps the crispys and all.
Second you can get a good gas pump for less than $200.00, I paid $180.00 for mine at Tractor Supply. You will pay at least that for a good vacuum pump, and then you will still have to manufacture the tank set up.
Third it is very neat. I have fittings in the ends of both hoses, so all I have to do is back in drop the tail gate put the suction hose in the 55gal drum I provided. Put the push hose in the barrel in my truck and start the pump. (And it is fairly quiet) My pump will pump at idle so its easy to control the flow rate. Then when Im done all I have to do is wipe the oil off the hose with a rag or paper towel put the cap on the fitting in the end of the hoses so no oil drips out and close the tailgate and away I go. No fuss no mess.
Murph,
Sorry for the late reply. I'm in western Pa. The pump's brand name is Champion, I'm not sure of the GPM on it but I have it bushed down to 1" hose for easier handling. I'm out of town on business for a week when I get back I'll try to get a photo for you.
The SS looks easy enough from the picture. Can you provide any more details on the 12 volt vacuum pump (brand, where available, size, etc.) and the 'plumbing' portion of the assembly? How long does it take to draw vacuum on a 10, 20, 40 gallon tank? THANKS.
I may have to try that. I also have a very small 2 stroke generator, but it's noisey. I sure would like see some plans on the 'plumbing' part of the tank other than just the photo. Can you direct me where to look for them? Thanks again.
I just want to know how to read an article, I am already signed in.
Huh??????????
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
