460 vs Diesel - Ford Truck Enthusiasts Forums
460 vs Diesel
Old 04-18-2007, 08:07 PM
bigmuddyford bigmuddyford is offline
bigmuddyford is starting off with a positive reputation.
460 vs Diesel
Alright people. Is there anyone out there with a 460 or any gas for that matter hooked to a Powerstroke or Cummins, anyone pulled a diesel. If so what all have you done to your rig. Thats my goal (to hook up to these hot shots in there daddy's diesel and yank the snot out of them) Anyone have any war stories of hooking. I hooked up to my daddy's 07 f150 and broke his front drive shaft. I will say, he spun all 4 wheels until it broke. But other than that he is the only one that will hook to me. Everyone else hears 460 and runs or they have one bad *** diesel and i run. Ive never ran into a stock diesel that would hook up. Well i hope to hear some good stories. Ohh and as for a duramax....my toyota could pull that.
Thanks
CHRIS
Old 04-18-2007, 10:15 PM
Troy Bredthauer Troy Bredthauer is offline
Troy Bredthauer is starting off with a positive reputation.
i tried truck pulling for a couple of years, weight seems to be the biggest factor. and diesels are heavy. ive got a 95 f350 with a turned up cummins in it and it takes one hell of a 460 to out accelerate it. the 460 is in a half ton but it does have 37 goodyear mtrs on it. the 460 always wins on the big end however because the f350 tops out at 115. i do think that the deisel will always win the pulling contest though. it doesnt please me, however because i HATE diesels
Old 04-19-2007, 02:56 PM
MychalCrowson MychalCrowson is offline
MychalCrowson is starting off with a positive reputation.
Anybody have Speed Channel? Every now and the they show tug o wars, of course its on pavement with non DOT legal mud tires, but the trucks with 460's always win. the last one i watched was a 78 Ford with a 460 vs. a 95 powerstrke and the 78 pulled him with ease. Dirt i guess could be different, weight is a huge factor and i'd have to say it would be hard to budge a turned up heavy *** diesel, but if you have it set up right with the right tires and maybe a 545 stroker they'll have nothing on you in the torque dept. Another thing, diesels may win a tug o war, but i go to a tractor pull every sept. and watch all pickups new diesels vs. old truck with gas motors and i have yet to see any diesle win in any class. In the 7200lb class their was a few dodge diesles,chevy duramaxs and powerstrokes all turned up and they all got beat by a 72 chevy on 40 in swampers and i nice torquey 454. diesels do make killer torque, but there is a little more to it then that and a nice big block can do some serious torquin, plus they sound alot better
Old 04-19-2007, 04:13 PM
stngh8r stngh8r is offline
stngh8r is starting off with a positive reputation.
Wink
traction wins tug o war, not neccessarily power. IMHO.
I could out pull a much more powerful truck any day of the week as long as he doesnt have the same strategy as I do.
Somebody says go.....hold the brake until your competition starts spinning, then ease off the brake and on the gas while he is still spinning and you have traction. You move forward and he moves backwards! Rocket Science
Old 04-19-2007, 09:52 PM
ha ha thats a great plan, i just hope no deisel guys are reading this, pull smarter not harder. an auto tranny probably helps alot also.
Old 05-13-2007, 09:36 PM
KubotaOrange76's Avatar
KubotaOrange76 KubotaOrange76 is offline
KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.
if your pulling another truck hooked bumper to bumper....it doesnt matter whats under the hood, all that matters is weight, traction and the height of the hitch points
Old 05-23-2007, 05:18 PM
mgraveman mgraveman is offline
mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.
That is a trick I use when pulling on somethign sometimes. I hitch up to the gooseneck ball and let the weight pull me down. I get great traction this way, and in your case it would pull the other guy up off the ground some.
Old 09-10-2008, 12:22 AM
edgewatergetitboy edgewatergetitboy is offline
edgewatergetitboy is starting off with a positive reputation.
well my 1990 f-250 with a 302 in it will drag my 94 f-250 with the 7.3 in it all over the place, but thats only because of the gearing in the 1990, its got 4.11s and some meaty tires and the 1994 has 3.73s and some 33 bfg a/ts. but i have a 84 ram charger with a built up 360 in it that dragged my buddys stock 2500 dodge 4x4 with a cummins in it.
Old 09-10-2008, 11:57 AM
northern 7.3 northern 7.3 is offline
Temporarily Deactivated
northern 7.3 is starting off with a positive reputation.
Quote:
that doesn't work. i have a diesel and tugged against my buddy with v10 superduty. i tried that and he was skidding me backwards on pavement till i started in on the throttle a little bit and then pulled him back. my diesel is a 91 7.3 ats turbo. nothing fancy, not really that powerful and i had nothing in it aside from me and a little bit of fuel. i still weighed just over 6500lbs. his weighed 6200 and he had new tires i had old ones.
if you want to beat a diesel you'll have to have good tires, add some weight and dont light your tires up. nice easy pulling without spinning if at all possible. if youre on pavement anyway.
Old 09-10-2008, 12:14 PM
I can't believe there's really that many people out there that do this!
I might do it on dirt, but not on pavement.
Old 09-10-2008, 01:27 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
Quote:
Well we had a pull here locally and at the end they have a local pull (you have ot have local county plates) we had half and half 4 diesels 4 gassers including one F250 with a 460 as well as a couple SBC and one BBC. we had 2 cummins, a 6.0 powerstroke and my 7.3 powerstroke. I came in third at 297ft (one cummins was at 313 the 6.0 was at 308 and the other cummins at 295) they closest gasser was at 270ft so no gassers don't always win, like a lot of stuff truck pulling is about wheel speed (which is where I messed up as it was my first hook every and didn't get into the right gear soon enough) even messing up and never really getting my wheel speed above 20mph I still outpulled the 460 by almost 30ft.
Oh and I do run gasser motors just not for pulling. most pulls around here have made a seperate class for diesels becuase the gassers complain of an unfair advantage.
Old 11-17-2008, 03:32 AM
maxell3655's Avatar
maxell3655 maxell3655 is offline
maxell3655 is starting off with a positive reputation.
Pulling has alot to do with weight and traction. Diesels are more high end (so they have an easier time with traction at the start) and gas are more for low end torque. My friend was at a truck pull on cruise night and a 454 and a 460 went head to head. Both trucks and they were there for easily a good 5 minutes in the same spot smokin them. Both had no weight in the bed. i am pretty that the 460 won cause it had more weight. Anyways i looked up diesel motors and found that the turbo diesels had more torque then the non turbo and the 460 sat right in between them. Im talking 96 and under. It might be the same case with newer trucks.
Old 11-17-2008, 04:40 PM
polish pete polish pete is offline
polish pete is starting off with a positive reputation.
Quote:
just to add to this, your wrong about diesels, there almost always lowend torque, unless they have a massive turbo and it lags. peak torque in small diesels are like 1800 not sure, but in the bigger diesel engines there peak torque is probably like 1300-1500.
Old 11-17-2008, 05:24 PM
maxell3655's Avatar
I know someone that just bought a brand new turbo diesel and someone asked him if it would be easy to smoke him and he said that it was more for high end power on a highway for towing.
Old 11-17-2008, 06:07 PM
DirtStripHero's Avatar
DirtStripHero DirtStripHero is offline
DirtStripHero is starting off with a positive reputation.
We took my 460 to a truck pull in Indy this past summer and they didn't even have a gas class. We didn't want to drag it all the way back home for nothing so we went ahead and pulled with the diesels. The only rules were it had to have plates and insurance, and be under 7200lbs. My 460 was completely stock at the time and we pulled even with most of the pure stock diesels. (Which was about 3 of the 30 trucks there) These were mostly late 7.3L or 99-04 Dmaxes. However we were no where near anyone that had a chip, programmer, or cummins.
ultimate sacrifce paid by this so called"dead beat dad" cjben General NON-Automotive Conversation 27 05-03-2016 11:41 PM
Hooking up fuel shutoff solenoid flainn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 09-23-2012 04:43 PM
300 vs 5.7 tjthegreat 1987 - 1996 F150 & Larger F-Series Trucks 94 02-12-2008 11:01 PM
Spartan Diesel Tunes and Powerstroke Warranty Boo_Daddy 6.0L Power Stroke Diesel 28 08-28-2007 07:44 PM
how hot is too hot? SwOkcOffRoader Cooling, Heating, Ventilation & A/C 25 12-14-2004 08:39 PM
Tags
460, 60, 73, chips, computer, cummins, diesel, engine, f350, ford, gas, mtrs, psd, tug, versus, vs, war
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
