Door and Ignition locks: - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 04-18-2007, 06:05 PM
blockheadbob's Avatar
blockheadbob blockheadbob is offline
blockheadbob is starting off with a positive reputation.
Does anyone know where I can get a set of door locks and ignition switch keyed the same.
Thanks, Bob
Old 04-18-2007, 06:30 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
Only your door, liftgate, and glove box locks can be keyed the same (all four locks use the same key), as the ignition switch is a different key design. Dare I ask why you need replacements? Not sure whether it would cost more to have a good locksmith make keys or to buy new lock cylinders. I believe the only place you can get any of those are at a dealership, if you want all-matching stuff, every resource I know of or can check doesn't have anything.
Old 04-18-2007, 07:18 PM
my72ford my72ford is offline
my72ford is starting off with a positive reputation.
when i got my b2 several years ago..all i had was an ignition key..therefore i could not lock my doors,i went to a locksmith shop and they charged me $75 to key the locks and make me a couple of new keys..it was worth it than having to go through all the trouble of having to replace the lock cylinders...price around,it will cost more for them to come onsite,than if you bring it to them
Old 04-20-2007, 08:54 AM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
You can buy the new ignition lock and then get older Ford door cyls that matches the ign key (example - older vans), recode them, and just swap your cam over.
Old 04-20-2007, 12:49 PM
mishqua mishqua is offline
mishqua is starting off with a positive reputation.
You can go to your local auto parts store for the door locks they cost 20-30 dollers ( actual ford locks ) they are easy as pie to install. I had someone try to break into my truck, lucky for me they sucked at the time as car theives cause they punched the lock all the way thru and lost the rod at the bottom of the doors. As for the ignition just go find a wrecking yard and pull one that has the key that is not worn down. The wear on the key will tell you if the lock has had a hard life. If its all worn down look for a diffrent one,
Old 04-20-2007, 10:44 PM
Eric C.'s Avatar
Eric C. Eric C. is offline
Eric C. is starting off with a positive reputation.
NAPA is the best for doing this and they can be ordered as a set. The other option is to go to the dealer some will tell you they can't but others will do the ordering. When I worked for U-haul we kept both the six and ten cuts as a set and rental companies still do it today. One Key all the locks. Also check online at Karr Products as they sold lock sets for a variety of vehicles.
Old 04-21-2007, 12:09 AM
NAPA must only do that in-store, because I couldn't find ***** on their online catalog (as with every other online catalog for well-known auto parts stores, not to mention EVERY other parts source I have bookmarked!). Good info to know, though, thanks Eric! I'll keep that in mind if I have to re-key my truck(s).
EDIT: Did a search for Karr Products and didn't get anything that resembled what would be relevant. Do you have a hyperlink, Eric?
Old 04-21-2007, 11:56 AM
Door Locks
I dont need a feplacement I just like the one key system on my 78 f-150 and the wifes expedition better. I'm just trying to convert the bronco II.
Thanks,
Bob
61 f-350 ignition switch install EglsMntnFab 1961 - 1966 F-100 & Larger F-Series Trucks 6 02-11-2013 05:47 AM
electrical problems andrew034 1999 - 2003 7.3L Power Stroke Diesel 0 08-25-2012 08:05 AM
Ignition Switch Replacement - '55 F100 bbearls 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-13-2007 10:26 PM
super duty door locks won't open with key bob wtrguy 1999 to 2016 Super Duty 2 11-11-2004 05:13 PM
Child safety locks bobward737 Expedition & Navigator 13 02-01-2003 02:01 PM
Tags
87, bronco, ford, ignition, key, locks, set
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
