Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-17-2007, 09:52 PM
PAFordFan is starting off with a positive reputation.
Engine code on E250
2001 Econoline V6 4.2
I got these codes but am having trouble finding the definition as to the cause.
P1270 Engine RPM Vehicle speed limiter reached
P0174 Systen too lean (Bank 2)
P1151 Ho2S Bank 2 Sen 1 in Suff switching lean mean.
How can I find out what parts I need or any other info tohelp me fix it?
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-18-2007, 12:53 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Welcome to the forum
The second two can be caused by a dirty MAF or a bad PCV hose elbow. Shes running too lean.
The first code means that the engine has turned enough rpm to reach the rev limiter.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 04-18-2007, 09:16 AM
Thanks for the reply. Yes, she has turned alot of rpm's. 200 k miles on it.
Is this a fixable code or do I just clear it out after I solve the other 2 codes?
Its a work van that I want to run till it drops.
Thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
