Burning Used Motor Oil - Ford Truck Enthusiasts Forums
Old 04-17-2007, 07:26 AM
oldpaintguy oldpaintguy is offline
oldpaintguy is starting off with a positive reputation.
Has anyone tried used motor oil as a fule in the 7.3 engine?
Old 04-17-2007, 08:20 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Not a good idea, but read this anyway: http://www.ford-trucks.com/forums/44...motor-oil.html
Old 04-17-2007, 08:56 AM
mechmagcn's Avatar
mechmagcn mechmagcn is online now
Diesel Junky
mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.
While I don't run used oil in my 7.3, I do run a 25% mixture in my 6-71 Detroit.(the old 6-71 really doesn't like this new fuel) When I have clean hydraulic fluid, I will run as much as 50% mixture of it. I have run this engine for several years at these rates with no adverse affects.
I have a friend who is running an older Mecedes 4cylinder non turbo on 75% used oil and 25% gasoline. He has run this car for over 2 years like this, and has no problems with it. He does have a mixing system which filters down to 2 microns.
Old 04-17-2007, 09:06 AM
firemediceric's Avatar
firemediceric firemediceric is offline
firemediceric is starting off with a positive reputation.
Coincidence that I just posted a similiar question here:
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/9751014871/m/5101055591
In reading the above link from Fabmandelux, it seems that some have run UMO with next to no filtering. In my query on the other forum I am talking about processing it just as I do my WVO, which many call overkill in the steps I take. This would include a mistwash for acids, settling, heating to seperate water and filtering down to 1 micron nominal.
Old 04-17-2007, 10:37 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
I have a friend they run 50/50 on the farm.
I think they only run 25/75 in the trucks if they do though.
If you are going to mix in motoroil, Filter it good. There are metal particles in the oil, injectors probablywont like them much.
I would Mix it slow. start out with a small mixture if your serious with it. only 10/90.
To much and they get a little cranky. Anotehr guy on here tried it though, he said that his ford took a dump. =*( poor truck.
Old 04-17-2007, 02:01 PM
tx4wd tx4wd is offline
tx4wd is starting off with a positive reputation.
Quote:
Do you recall some keywords in the thread so I can find it? This is something I've been seriously considering as I'll be picking up an older diesel soon....maybe today
Thnx.
Old 04-17-2007, 02:39 PM
Talyn's Avatar
its in one of the current active threads here.
Old 04-17-2007, 02:41 PM
Talyn's Avatar
Old 04-17-2007, 02:57 PM
Red face
Last edited by tx4wd; 04-17-2007 at 03:08 PM. Reason: disregard---didn't click to page 3...duh
Old 04-17-2007, 03:19 PM
Talyn's Avatar
what kinda look is that?! haha
Old 04-17-2007, 03:24 PM
That's the look that I posted that I didn't see where his motor blew up but where it only clogged the filter then after posting my response here I realized I hadn't clicked to page 3....since I can't delete posts here just dropped it to an embarassed look.
Used Motor Oil catbird7 Bio-diesel, Propane & Alternative Diesel Engine Fuels 79 01-12-2008 11:31 PM
What Brand Of Motor Oil Do You Use? Beachbumcook 6.0L Power Stroke Diesel 29 07-05-2007 08:42 AM
Oil Brand ranger rules General Automotive Discussion 20 06-04-2007 06:23 AM
flathead oil ddurant 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-30-2003 12:58 PM
best motor oil viscosity jamie m Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 03-03-2003 01:34 AM
Tags
69, 73, blend, burn, burner, burning, diesel, engine, f250, ford, forum, fuel, mercedes, motor, motoroil, oil, powerstroke, run
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
