6.4L Muffler or Muffler-delete pipe?
Originally Posted by jvoigt
Well it should have some way of letting outside air enter the exhaust flow before it exit's out the tip, It will look similar and function similar to the factory intercooled tips.
NIck
Originally Posted by rollerstud98
the guy at the shop won't be the one to ask, i highly doubt he qualified to say that the intercooled tips do not make a difference
Nick
Ask him if he anticipates any problems with that tip not cooling down the 1200 degree regen temps that will be comeing out of that puppy. Maybe he just doesnt under stand that the exhaust gets re-heated at the DPF during a regen and exhaust temps will climb right up to 1200 degrees or so and unless there is an intercooled tip to allow some cooler air to mix with that exhaust flow it could be a problem.
Nick
Actually I know that the MBRP tips are Intercooled on there kits for the 6.4L but I still have no idea about Magnaflows kits.
Nick
All I can say is that it is ILLEGAL to remove the DPF for anything other that a factory cleaning. Maybe a Ford tech will chime in and tell you all about the DPF.
The other thing that sux about the new emissions legislation is it puts a damper on power chips. The new engines run in a high Nox/low soot mode all of the time so the dpf is loaded with the same amount of soot regardless of engine load. Since the DPFs on these trucks don't have a DeltaP sensor to measure the difference in pressure between each side of the filter, the engine's software is programmed to regen at specific intervals knowing how much soot it has produced based on a calculation. If a powerchip is installed and doesn't take into account any additional soot produced above what the engine thinks is being produced, there is a good chance the dpf will become plugged before a regen takes place. The catalyst also needs a source of oxygen to cause the exotherm reaction. The extra NOx provides this source. It is later burned off by the catalyst like a gas burner's catalytic converter reduces Nox.
Ok I was mistaken about the MBRP systems. From what I can tell the single exit kits do not have any type of intercooling but the Cool Dual kits do have Inter-cooled pipes....not the tips but their are louvers in the pipe right before the area where the tip connect's, they have picture's of the single-out and Dual-out kits but only in the pictures for the dual-out kit can you see what there answer is for the intercooling which appears to be louvers on the pipe.
Links; http://www.mbrp.com/picturepop.php?c...uperDuty&pic=2
another angle; http://www.mbrp.com/picturepop.php?c...uperDuty&pic=5
Originally Posted by cHiLi 11
So I am lookin all over the net, and from what I saw the MBRP kit said nothing about an intercooled tip the kits I saw from them? I even went to their home site and it just says a 5" double walled tip which is exactly what I have. Now I know the MagnaFlow tip comes intercooled, so where did you see that?
Nick
Nick
