bucket heater? - Ford Truck Enthusiasts Forums
bucket heater?
Old 04-16-2007, 02:13 PM
superpony18 superpony18 is offline
superpony18 is starting off with a positive reputation.
bucket heater?
I have read about people using a water heater element and an extension cord to make a bucket heater, is that all there is to it?. My oil is to thick to pump when I get it so I am looking for options. Just rapping up the loose ends on my processor, should be making bio by May.
Old 04-16-2007, 04:13 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
Quote:
Yes it is. Some people use 220 volt elements. The 200 volt element will not get as hot as the 120 volt element.
Old 04-16-2007, 07:50 PM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Gun-Driver is starting off with a positive reputation.
Thatís what I use to heat the oil that is in the 55 gal. drums I have outside the restaurant. Itís a 4500 watt 220 hot water heater that I attached to the end of an extension cord (12 gauge). I threaded it into a 1" iron pipe coupling and attached the ground to the coupling. I just hang it in the drum for about 10 to 20 minutes depending on how cold it is and stir it once in a while. I also use a gas powered 2" trash pump to pump the oil into my drum in the truck.
Old 04-16-2007, 08:11 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
I found someting today that might do the trick. let me upload the picture!
Old 04-16-2007, 08:21 PM
Talyn's Avatar
Apparently its used to start charcoal by super heating it. It works like a soldering iron.
Says it reaches tempatures of 1000 Deg F.
Which if thats to hot at 120v's (110) then you can always jump it down.
Just like the cooking elements on a stove, or those table top stove/cooker deals.
i figure this would do really good for heating oil if used properly.
Thoughts?
Old 04-16-2007, 08:48 PM
Thanks for the responses guys, wanted to make sure before I tried.
Old 04-16-2007, 11:54 PM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
Thoughts?
I'll wager it won't get anywhere near 1000 degrees when its submerged in liquid. Which is a good thing.....
Old 04-17-2007, 12:02 AM
Talyn's Avatar
no, but for 9 dollars, it will heat your oil.
Thats the beauty of it!!!
Just drop it in whatever drum you need, and let it do its work.
Old 04-17-2007, 01:41 AM
Gun-Driver's Avatar
Basically the same thing I use , I just used the top element out of the hot water tank I was converting. Looks to me like it should work as long as it doesn't get to hot - that would be one heck of a grease fire.
Old 04-17-2007, 09:39 AM
Talyn's Avatar
Ya, I would have to test it, But i'm not into that phase of the plan yet.
It would be really simple to just drop the voltage lower so it does not get to hot.
The other solution would be to make a double boiler setup, and heat the oil with boiling water. That is overly compliacated however.
WTB Headlight Buckets for my '74 F-250 bowtieman55 WTB - Parts & other 0 04-29-2015 10:32 PM
Need seal for heater core. 4x4 Bart 1973 - 1979 F-100 & Larger F-Series Trucks 44 03-07-2014 12:39 PM
need parts for 79 bronco sammy78 1978 - 1996 Big Bronco 0 02-16-2013 09:28 AM
Bucket Seat Brackets repro'd yet? psquare7575 1967 - 1972 F-100 & Larger F-Series Trucks 12 06-28-2011 10:50 PM
Block Heater installed in 07 4x4 Expedition Newton007 2007 - 2014 Expedition & Navigator 0 07-28-2007 12:02 AM
Tags
220, antique, bucket, build, charcoal, heater, heaters, heating, iron, make, oil, soldering, truck, volt, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
