Any trick to replacing push rod cover gasket?
The push rod cover on my 79 F150 is leaking pretty good and it looks fairly easy to replace the gasket. Just label and pull the plug wires, remove the coil and remove the pushrod cover bolts.
Am I under estimating the task? Does anybody have any gasket installation advice to help me avoid having to do the job twice?
Thanks
-Tony
Thanks
-Tony
sealer on the square gasket is your preference. I typically just make sure everything is perfectly clean and just put a couple dabs of glue on the cover side to hold the gasket in place as you install.
As for the grommets, i have never gotten them to seal using a sealant. They've always leaked on me unless it was rubber straight to steel.
Justin
Justin
waco1313
12-07-2015 10:25 PM
hillcountryflt
19
06-26-2014 11:35 AM
