1978 - 1996 Big Bronco
'86 Bronco - no start
Old 11-04-2001, 11:31 PM
jason86's Avatar
jason86
jason86 is offline
My '86 Bronco with FI 302 will not start. I have spark, but no fuel. I pulled the fuel line off the engine side of the filter and have pressure there. Where should I go from there? Relays, pumps, regulators? Please Help!
Thanks!
Jason
Old 12-02-2001, 03:35 PM
albertaguy's Avatar
albertaguy
albertaguy is offline
Did you ever get it going and if so what was it.
I have the exact same problem
Old 12-02-2001, 04:48 PM
jason86's Avatar
jason86
jason86 is offline
[updated:LAST EDITED ON 02-Dec-01 AT 05:49 PM (EST)]Yes I did get it running. I had another guy look at it and he found that the small wires running into the ign. coil and fuel injector harness were loose and not making a good connection. Check all your wires. You may have to check each. injector to see if its getting the correct voltage.
Good Luck
Old 12-02-2001, 04:54 PM
jason86's Avatar
jason86
jason86 is offline
jason86
11-03-2015 07:47 PM
edsherman
12-06-2008 08:43 AM
jason86
Paint & Bodywork
10-19-2004 12:34 PM
jason9009
10-24-2002 10:09 PM
jason86
01-03-2002 10:07 AM
Quick Reply: '86 Bronco - no start
