E-250 rear differential fluid change - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 04-15-2007, 03:07 PM
glasstruck glasstruck is offline
glasstruck is starting off with a positive reputation.
Hello, I've got a e-250 van with the 4.2 v-6 motor. I want to change the rear end fluid and am curious what axle ratio I've got. On the driver's side door jamb, the sticker says the axle code is 24, what does that mean?
Also, any tricks to changing the fluid? There's a plug about 1/3 to 1/2 up the rear cover, but I'm sure I've got to pull the cover to drain the fluid? New gaskets? Should I use the Ford gear oil or something else? This van is worked pretty hard on a daily basis.
Thanks,
Jim
Old 04-15-2007, 03:27 PM
maples01's Avatar
maples01 maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
Fluid is synthetic, Ford fluid price is nuts, plus if you have a limited slip like me, you gotta run a friction modifier, holds 3 1/2 qts BTW. I bought Royal Purple synthetic gear lube from the speed shop, cheaper than Motorcraft, far better and needs no friction modifier. The cover needs no gasket, there aren't any, it's glued on, you use RTV sealer, it's hell to get off, so you have to work at it, chizeling around the cover until it finally pops loose on one side. Mines a 99 E-350, the tag bolted on one side of the cover, under one of the hold down bolts says 3.50 and limited slip.
Old 04-17-2007, 07:14 PM
Club Wagon Club Wagon is offline
Club Wagon is gaining momentum as a positive member of FTE.
To eliminate the possibility of an axle swap don't rely on the door jamb sticker, look at the tag on the axle itself.
That plug is the fill hole & establishes the proper fill level. Quickie rear end oil changes are sometimes accomplished by using a suction pump to draw out the old oil-I don't recommend it, but if your paying to have somebody else do it be sure to specify. When you remove the cover to drain oil properly you have a chance to inspect the ring, pinion & bolts, as well as clean out any debris that has accumulated on the bottom of the housing. Some place a magnet inside to collect any steel that might circulate. Older Econolines did have gaskets & my parts store was unable to be certain which gasket to sell me by the numbers! I took 2 & had to match what I found & return the other. Be sure you use the friction modifyer required for limited slip.
Transmission fluid everywhere jackedup10 1999 - 2003 7.3L Power Stroke Diesel 5 06-04-2016 06:47 PM
Rear brake line routing question rworld Excursion - King of SUVs 7 01-18-2016 03:37 PM
Changing Drive-Train Fluids cber Explorer, Sport Trac, Mountaineer & Aviator 2 09-13-2014 11:09 PM
Fluid leak; air con compressor? 211oakland 1968-2013 Full Size Vans 4 03-07-2014 05:57 PM
08 F250 differential service??? LMS Residential 1999 to 2016 Super Duty 7 08-13-2012 02:14 PM
Tags
2004, 2007, change, corrrect, diff, differential, e250, e350, fluid, ford, gear, limited, oil, rear, slip, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
