How to change the PCV valve.. - Ford Truck Enthusiasts Forums
Old 04-15-2007, 12:55 PM
DJdemon6696 DJdemon6696 is offline
DJdemon6696 is starting off with a positive reputation.
i know how to change it but how to get to it ? its behind the intake and hard to get to ... any tips?
i know for shure its clogged.. and need to be replaced
Old 04-15-2007, 03:10 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
It's a pretty tight fit on the 351, but there's a little give to the grommet, so pull it out until it touches the intake, then pull/push it toward the back of the engine while still pulling it out, and it should pop out. Sometimes it helps to pull the vacuum hose first. Bottom line is, you just have to force it a bit.
Jason
Old 04-15-2007, 06:26 PM
Red Raider 4x4 Red Raider 4x4 is offline
Red Raider 4x4 is starting off with a positive reputation.
I just changed mine on my 302, all I have back there is a hose, just get your hand under there, pull back and forth a bit, make sure your truck is cold, tricky part is just getting off the hose and back on. Its not bad though.
Old 04-15-2007, 07:29 PM
ok thanks that will be tomorow's project since i have no shool this week
and Red Raider4x4 still no succes with the truck ? does it still want to die?
Cab air filter jamhh 1997 - 2003 F150 3 10-10-2013 05:39 PM
how the heck do i change my front turn signal bulb? 02 Super Duty Guy 1999 to 2016 Super Duty 8 08-06-2013 07:39 AM
Mirror side marker light! How to change bulb??? F 250 6 liter 6.0L Power Stroke Diesel 15 03-06-2013 07:39 PM
Edge Evolution - change gauges on screen jbodin18 6.0L Power Stroke Diesel 5 07-17-2011 11:28 AM
how soon on plug change one5150fisher 2004 - 2008 F150 19 02-08-2007 08:08 PM
Tags
1987, 1997, 2005, 46, change, e250, f150, pcv, pvc, replace, trucks, valve, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
