Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-15-2007, 11:05 AM
jmagers jmagers is offline
Garage is empty, add now
jmagers is starting off with a positive reputation.
2.3L timing belt
Hi,
I'm in the process of changing a timing belt on a 2.3L engine. I removed the plugs and set the #1 piston on TDC on the compression stroke. I now have to remove the crankshaft pully. Can someone please tell me how I go about this without turning the crankshaft counter cloclwise?
  #2 (permalink)
Old 04-18-2007, 12:46 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
You may have to move the crankshaft a bit while you loosen the bolt and then reposition it at TDC before you take off the pully. Getting the bolt loose usually isn't too bad, I've used an air impact wrench which doesn't really move the crank but you can also put a socket with a breaker bar on it, rest the bar against the frame rail and bump the starter which pops the bolt free in an instant. But of course you then need to reposition the crank at TDC...
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 04-18-2007, 05:35 AM
Thanks for the reply. The new belt is on and car is running great! The impact air gun worked great
  #4 (permalink)
Old 04-21-2007, 12:15 PM
Old Rob Old Rob is offline
Old Rob is starting off with a positive reputation.
If it's in the car and a stick, you can put it in gear, apply the emergency brake. If you have a clutch thats starting to slip, that will show up too.
  #5 (permalink)
Old 04-22-2007, 07:08 AM
Thanks for the info
  #6 (permalink)
Old 04-27-2007, 07:48 PM
fordnut71 fordnut71 is offline
fordnut71 is starting off with a positive reputation.
u can also fill the cylinder with nylon rope threw the spark plug hole to break it lose
i do that 1st then break the crank bolt lose then remover the rope an roll the motor to tdc by hand. then u can remover the pully
  #7 (permalink)
Old 05-21-2007, 09:42 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
Many use this method: Use a socket and breakover handle. Put a cheater on the handle long enough to go under the passenger side frame. With the coils disconnected, have a bud hit the starter. This is usually enough to break the bolt loose. I would never put any foriegn material in the combustion chamber. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #8 (permalink)
Old 05-21-2007, 09:53 PM
If the belt is being changed for maintenance, the following method can be used, and is much easier for the novice as you don't have to worry about timing.
1: Pull the timing cover and access the belt.
2: Using a light colored marker, mark the belt and the cam sprocket at the same spot on the sprocket and belt in two different places.
3: Do the same with the auxilary sprocket, only space the marks differently so you will know which is which when you reinstall the new belt.
4: Mark the crank sprocket and belt. One mark will suffice as it is hard to access.
5: Remove the timing belt and lay it on top of the new belt lining up the belt teeth.
6: Mark the new belt even with the same marks you made on the old belt.
7: Install the new belt lining up the marks on the belt with the marks on the sprockets.
8: Tighten the idler tensioner.
10: Turn the engine over by hand a couple of revolutions in a clockwise direction when standing in front of the engine (normal crank rotation). Recheck your marks. (Note: Never turn a belted engine in the wrong direction. It is almost guaranteed to skip a couple teeth.)
11: If everything check, complete re-assembly, and drive happy. jd
__________________
Tags
2006, 23, 23l, 23lfordtimingbeltteethskip, belt, belts, drive, engines, escape, ford, liter, loosen, replacing, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
