04 250/350 vs 05 250/350 frame
Yes, The frame was changed. Here are the functional changes for 05
2005 F-250/F-350
Super Duty Pickup —
What's New
The following will give you a list of all that's new and important on the redesigned and re-engineered 2005 F-250/F-350 Super Duty Pickup trucks. Read on to learn about the new 3-valve V-8 and V-10 engines, the improved frames, suspensions and brakes, the new exterior and interior features, all of which add up to make this new Super Duty the tougher, more comfortable and the most capable pickup truck available. Detailed below are some of the changes and features built into the 2005 F-250/F-350.(1)
Functional Changes
New 5.4L 3V SOHC Triton™ engine now standard
— 300 horsepower, 40 more than last year
— 365 lb.-ft. of torque, 10 more than last year
— Uses Electronic Throttle Control (ETC), Variable Cam Timing (VCT) and Charge Motion Control Valves (CMCV) to achieve increases
New 6.8L 3V SOHC Triton V-10 available
— 362 horsepower, 52 more than last year
— 457 lb.-ft. of torque, 32 more than last year
— Uses Electronic Throttle Control (ETC) and Short/Long intake runners to produce "Best-in-Class" numbers
6.0L Power Stroke® V-8 Turbo Diesel receives a 10 lb.-ft. torque increase to 570 lb.-ft.
TorqShift™ 5-speed automatic transmission now available with all Super Duty engines and features Tow/Haul mode, which provides:
— Reduced gear search while ascending steep grades and improved engine braking on deceleration while descending hills
New 6000-lb. Twin-Coil Monobeam Front Axle/ Suspension on 4x4 models provides Best-in-Class axle rating and maximum front Gross Axle Weight Rating (GAWR) of 6000 lbs. for added load capability for special applications like snowplowing
New, more robust steering system and Twin-Coil Monobeam front suspension provides reduced parking effort and improved curb-to-curb turning diameter by as much as 5.1 feet
Rear suspension has been upgraded with new spring rates and staggered shock absorbers which improve axle control contributing to better ride and confident handling, loaded or unloaded. The new suspension delivers best-in-class payload and towing capability. The staggered rear shock absorber placement helps control axle windup to enhance traction for improved acceleration and braking
The 2005 F-250 and F-350 pickups now have best-in-class brakes. They provide better stopping distance, better overall thermal capacity and the most stopping power. This was accomplished through a number of improvements. The diameter of both the front and rear brake rotors has increased, which increases the total swept area of the brakes for heat dissipation. Stiffer calipers now feature larger pistons than last year for better braking feel. The brake pads have been improved and now last almost 50 percent longer on Single Rear Wheel (SRW) models and almost triple on Dual Rear Wheel (DRW) models
140-amp extra heavy duty alternator available with 6.0L Power Stroke V-8 turbo diesel engine
The frame has been upgraded from front to rear. New gussets have been added from the rear face of the engine crossmember that lengthen the frame's front box section for added strength. The gauge or thickness of the frame rails behind the boxed section has been increased from 10 to 17 percent (depending on model) to provide the strongest Super Duty Pickup frame ever
New long-lasting microcellular urethane body mounts help isolate the passenger cabin from noise, vibration and harshness
Major increases in Gross Axle Weight Ratings (GAWRs), Gross Vehicle Weight Ratings (GVWRs), Gross Combination Weight Ratings (GCWRs), payloads and trailer tow ratings (varies by model and equipment)
Exterior Changes
Bold new front grille with "sharper" edges
New "jeweled" dual-beam headlamps
New front bumper and upper fascia
All new 17- and 18-inch wheels
New larger 3-dimensional series badging
New bodyside and lower accent two-tone paint option on XLT series (Arizona Beige accent color now available on XLT)
Colors added:
— Dark Stone Clearcoat Metallic
— Dark Copper Clearcoat Metallic (King Ranch only)
Colors deleted:
— Estate Green Clearcoat Metallic (King Ranch only)
— Chestnut Brown Clearcoat Metallic (King Ranch only)
Interior Changes
New instrument panel layout with new gauge clusters
— Secondary glove compartment (requires automatic transmission and electronic shift-on-the-fly transfer case)
— Optional Trailer Brake Controller integrated into instrument panel
— Available upfitter switches integrated into instrument panel
— Gauge cluster includes TurboBoost gauge (diesel engine only)
— Engine hour meter displays the accumulated time the engine has run in the message center
New audio systems
— AM/FM stereo with digital clock
— Premium AM/FM stereo with CD player
— Premium AM/FM stereo with CD/cassette player
— Premium AM/FM stereo with 6-disc in-dash CD changer
Interior color Medium Parchment has been changed to Tan
Redundant audio and climate controls included in Lariat Luxury Package
Model/Series Changes
Lariat models now offer an available Lariat Luxury Package which includes:
— Electronic Automatic Temperature Control (EATC)
— Electrochromic rearview mirror
— Unique bronze-faced instrument cluster
— Enhanced message center with trip computer
— Redundant steering wheel controls for audio and climate control
— Unique woodgrain appearance trim on the instrument panel, door panels and center console (with optional Captain's Chairs)
Option Program Changes
Options added:
— Trailer Brake Controller, part of TowCommand™ system, integrated into instrument cluster design
— Upfitter switches (4) also integrated into instrument panel design
Options revised:
— Power moonroof now requires Advanced Security Group on XLT models
2005 F-250/F-350
Super Duty Pickup —
What's New
Functional Changes
Exterior Changes
Colors added:
Colors deleted:
Interior Changes
New audio systems
Options added:
Options revised:
I was told from our local Superduty Guru and Sales Manager that Ford made around 1200 changes to the truck between the 2004-2005 line up. This would include minor adjustments that a buyer wouldn't notice and takes for granted, to the major things such as thicker steel and items listed above.
I thought that was a significant number of subtle changes myself. A major factor in my buying decision making process.
I still miss the old 7.3 though. But I couldn't have it with the coil front end.
