rear end and no not talking about my bum MATT
ok I need some help finding somthing I was wondering if they make a posi rear end for the 7.5 inch rear ends in the rangers I got the non limited slip in the back end and wanna change it it's also got 3:45 back there would like to change that too if I can anyone know where I can get a used (perfer due to cost) or new if I have to or am I gonna have to swap out the rear axle to a explorer 8 inch or a ford 9 inch
I read in the Ranger forum that there's a Detroit Tru-trac available for the 7.5. The design is similar to the Torson l/s now standard in the new Ranger FX4 Level II. No clutch pack to wear out and the performance is said to be excellent. Don't know who might be able to order one(UAP?), but online ordering and shipping from the states is pretty easy. Check out the FTE sponsors as they usually offer discounts to FTE members.
As for a conventional L/s, a good local boneyard should be able to tell you what applications had a 7.5 l/s and whether they have one in inventory, unfortunately they'll likely tell you that you have to purchase the whole rear end at which point you may as well upgrade to an 8.8. And you'll likely have to replace the clutch pack as they degrade with use.
Good luck
Fred
Good luck
Fred
I am hopin to just find the cqage and keep my rear end in the truck tomuch work to swap out a rear end this close to show season and I was thinkin of goin to the 8.8 or the 9 but my dad keeps tellin me if it aint broke don't fix it so I will def lookin at the areo stars and if no luck there gonna order one
and one other stupid question lol whats a clutch pack I don't know much about rear ends
the clutch pack is inside the carrier its locked up by a spring in there much like the 1 in the transmission .its not hard to find a 8.8 for a ranger look at the wreckers its about $300-400
i have 1 in my 97 ranger with a 2.3
had a 4.10 gear set installed with a mustang carrier
droped it off at the shop to have the gear installed an everything an had it ready to go so i could just do the swap myself
My old Ranger had a locking 7.5 from the factory, gone before I got the truck though. I think the one B2 I had had a locking 7.5 too.
If you're going to swap rears, the 8.8 will be strong enough to handle anything you can do with your truck, like the future 5.0 upgrade. Don't bother with the extra expense of modifying a 9" to fit a non-factory application.
Oh, and for sources, check www.car-part.com
