Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Ontario Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ontario Chapter Join Chapter>, Leader: loudfords
  #1 (permalink)
Old 04-15-2007, 07:07 AM
cdncowboy's Avatar
cdncowboy cdncowboy is offline
Garage is empty, add now
cdncowboy is starting off with a positive reputation.
rear end and no not talking about my bum MATT
ok I need some help finding somthing I was wondering if they make a posi rear end for the 7.5 inch rear ends in the rangers I got the non limited slip in the back end and wanna change it it's also got 3:45 back there would like to change that too if I can anyone know where I can get a used (perfer due to cost) or new if I have to or am I gonna have to swap out the rear axle to a explorer 8 inch or a ford 9 inch
  #2 (permalink)
Old 04-15-2007, 11:04 AM
fflintstone's Avatar
fflintstone fflintstone is offline
fflintstone is starting off with a positive reputation.
I read in the Ranger forum that there's a Detroit Tru-trac available for the 7.5. The design is similar to the Torson l/s now standard in the new Ranger FX4 Level II. No clutch pack to wear out and the performance is said to be excellent. Don't know who might be able to order one(UAP?), but online ordering and shipping from the states is pretty easy. Check out the FTE sponsors as they usually offer discounts to FTE members.
As for a conventional L/s, a good local boneyard should be able to tell you what applications had a 7.5 l/s and whether they have one in inventory, unfortunately they'll likely tell you that you have to purchase the whole rear end at which point you may as well upgrade to an 8.8. And you'll likely have to replace the clutch pack as they degrade with use.
Good luck
Fred
  #3 (permalink)
Old 04-16-2007, 07:27 PM
fordnut71 fordnut71 is offline
fordnut71 is starting off with a positive reputation.
some of the awd aerostars have them
look for 1s that are 4.0l awd an extended vans
most 3.0l awd shortys never got them
  #4 (permalink)
Old 04-16-2007, 07:50 PM
cdncowboy's Avatar
I am hopin to just find the cqage and keep my rear end in the truck tomuch work to swap out a rear end this close to show season and I was thinkin of goin to the 8.8 or the 9 but my dad keeps tellin me if it aint broke don't fix it so I will def lookin at the areo stars and if no luck there gonna order one
and one other stupid question lol whats a clutch pack I don't know much about rear ends
  #5 (permalink)
Old 04-16-2007, 08:13 PM
the clutch pack is inside the carrier its locked up by a spring in there much like the 1 in the transmission .its not hard to find a 8.8 for a ranger look at the wreckers its about $300-400
i have 1 in my 97 ranger with a 2.3
had a 4.10 gear set installed with a mustang carrier
droped it off at the shop to have the gear installed an everything an had it ready to go so i could just do the swap myself
  #6 (permalink)
Old 04-17-2007, 11:13 AM
loudfords's Avatar
loudfords loudfords is offline
1979 Ford F-150
loudfords has a good reputation on FTE.loudfords has a good reputation on FTE.
My old Ranger had a locking 7.5 from the factory, gone before I got the truck though. I think the one B2 I had had a locking 7.5 too.
If you're going to swap rears, the 8.8 will be strong enough to handle anything you can do with your truck, like the future 5.0 upgrade. Don't bother with the extra expense of modifying a 9" to fit a non-factory application.
Oh, and for sources, check www.car-part.com
__________________
Chad - loudfords - Ontario Chapter Leader
Click HERE to join the Ontario Chapter
1979 F150 351W
2003 Explorer XLT
  #7 (permalink)
Old 04-17-2007, 11:31 AM
cdncowboy's Avatar
nice nice I will keep the 8.8 in mind as a last resort fer sure or for when I do the 5.0 lol gotta ask the wife lol
  #8 (permalink)
Old 04-17-2007, 04:30 PM
sewerat's Avatar
sewerat sewerat is offline
sewerat is gaining momentum as a positive member of FTE.
if i'm not mistaken when i was looking into a 5.0 for the mazda the 4x4 rangers all had an 8.8 right? the 4cyl mustangs had the 7.5 and the 5.0s had an 8.8 or did they all have a 9? if so an 8.8 should be an easy find at a wreckers now adays and be an easy install?
  #9 (permalink)
Old 04-17-2007, 06:58 PM
i looked last night at car parts an there was 2 8.8 in kitchener but they are pricey
u could also use a explorer but it will drop the rear end almost 3 inches
if u plan on lowering u could use 1 of them with drop beams an still keep the ride quality
  #10 (permalink)
Old 04-17-2007, 07:14 PM
cdncowboy's Avatar
hell no no lowering for this guy lol I like a truck to be a truck not a car lol
  #11 (permalink)
Old 04-18-2007, 11:12 AM
loudfords's Avatar
1979 Ford F-150
How would an explorer axle lower the Ranger???? Ride height is dependent on the suspension, not the axle.
__________________
1979 F150 351W
2003 Explorer XLT
  #12 (permalink)
Old 04-18-2007, 03:58 PM
cdncowboy's Avatar
ok I found one whoo hoo no need to swap axles just the inners I am excited I really didn't want to do a axle swap
  #13 (permalink)
Old 04-18-2007, 07:12 PM
a ranger has a slug under spring axle an a explorer has a over slug axle
so if u put the axle on top of the spring it will still drop without anything being done to the suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
