best oil for engine over 200,000 miles - Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Old 04-14-2007, 11:51 PM
hatchet's Avatar
hatchet hatchet is offline
hatchet is starting off with a positive reputation.
My 94 250 has over 200,000 miles it takes 5w30 oil.but what would be the best type of oil to keep this engine running its best for a long time?thanks
Old 04-15-2007, 02:10 AM
Ed Ed is offline
Ed is gaining momentum as a positive member of FTE.
250,000 miles. I think your answer is right there in your question! Stay with a quality, brand name 5w30!!!
Dino oils, I'd say use Mobil 5000, TropArtic, or Chevron Supreme (5w30)
Synthetic Oil: Mobil 1, Royal Purple, Red Line. Any of these oils, following a 5,000 mile oil change interval, oil filter changed everytime, any engine will last a very long time.
Old 04-15-2007, 05:18 AM
PW01 PW01 is offline
PW01 is starting off with a positive reputation.
I'd stick with whatever got you there in the first place!
Old 04-15-2007, 08:53 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
I agree with the guys, continue using whatever got it to 200K miles.
I'd also add, if it's leaking/weeping at some seals, maybe consider a "High Mileage" formula, in the brand of oil you've been using, as it's seal softners could maybe help slow any leaking, or maybe even stop a weep.
If it's burning some oil, then look to your brands recipe that offers the best volitility, or lowest evaporation loss, & lowest ash number, as the first two may help cut consumption & the last could help cut combustion chamber deposits, if it's burning some oil.
Just a couple more thoughts for consideration.
Old 08-03-2007, 10:19 PM
Baja FX4 Baja FX4 is offline
Baja FX4 is starting off with a positive reputation.
Id go with a Diesel oil,either 10W30 if where you is a cold area.
Or 15W40 in a warmer place.
My truck seems to really like 15W40 in 120 degree Summers or 60 degree winters.
Im a Diesel mechanic and Im very impressed with how clean Diesel engines stay,even after 10,000 hours of use.
Old 08-04-2007, 02:28 AM
Ed Ed is offline
One added benefit of diesel rated oil, is it keeps engines clean that experience a lot of idling, plus it holds dirt and soot in suspension very well.
If nothing else, if you use a 10w30 oil, add a quart of diesel rated oil (10w30) as your last quart.
I have no problems with diesel rated oils used in any gasoline engine that does not have a catalytic converter. On a emmsion controlled engine that has a CAT and oxygen sensor, I would limit the diesel rated oil to one quart of total capacity.
Old 08-04-2007, 04:30 PM
Indybroncoman's Avatar
Indybroncoman Indybroncoman is offline
Indybroncoman is starting off with a positive reputation.
If it's not burning any oil stick with what you've got. If it does burn oil, try moving up incrementally until the problem is fixed. Start with 10W30, then go 10W40, etc. until it's not buring as much oil.
Old 08-22-2007, 11:39 AM
MLCRI$I$ II's Avatar
MLCRI$I$ II MLCRI$I$ II is offline
MLCRI$I$ II is starting off with a positive reputation.
I would think that whatever oil has taken you to 200K is probably the one to stick with.
Old 08-22-2007, 04:43 PM
Diesel Man 03 Diesel Man 03 is offline
Diesel Man 03 is starting off with a positive reputation.
I say if you got to 200k on some kind of 5/30 keep using it.
Best vehicle to make it over 200K miles - F250 RightWingNutJob 1999 to 2016 Super Duty 2 02-26-2016 09:40 AM
200k+ mile club. Vehicle info with post. 4x4pwr 1999 to 2016 Super Duty 8 01-02-2016 10:45 AM
Synthetic oil/200,000 miles gfmk 6.0L Power Stroke Diesel 22 04-17-2012 12:58 AM
which oil weight is best for older explorer cabledog77 Explorer, Sport Trac, Mountaineer & Aviator 4 12-28-2011 10:14 AM
From Synthetic Back to Regular Motor Oil Scrapiron66 Oil & Lubrication 4 01-15-2004 10:08 PM
Tags
200000, 200k, 250000, 5w30, bronco, engine, engines, it, kind, mile, miles, motor, oil, truck, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
