Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Competition Diesel racing, sleds, dynos, power tuning and max performance.
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 04-23-2007, 04:45 PM
SpartanDieselTech's Avatar
FTE Sponsor
SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.SpartanDieselTech has a great reputation on FTE.
Quote:
Uh huh...How do you know that? Ever driven or raced a Titan?
...one tune from Stillen, and you'll be lookin for more than a tune from matt.
My friend,
Our Ultra Comp files turn consistent 5.0 0-60 times during a powerbraked 4x4 launch in Crew Cab Short bed trucks.
The Supercharged Nissan's are claiming 420 RWHP (according to Motor Trend). We produce 445-450 RWHP depending upon calibration and well over 200 ft-lbs that the Nissan does not have. Tuning will put a 6.0 in the mid to high 13-second quarter mile range- The Titan claims a 14.5.
So, to put it breifly- the tuned 6.0 will produce ~30+ HP and ~200 lb-ft more, 3/4 of a second in the quarter mile and around a 1 second 0-60 quicker over the Titan.
Not to mention, the Stillen Supercharger is a $4,700 modification... our tuners are a $450 one Shall we throw 4250 more dollars at the SD and watch the fireworks?
__________________
Visit the Spartan Diesel Technologies Website
Matt Geouge
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 04-23-2007, 11:45 PM
jim6liter's Avatar
jim6liter is starting off with a positive reputation.
Thats good stuff right there.
__________________
04'F-250 6.0 PSD.CC Dk.Shadow Gray.XLT SPORT FX4 TT Mirrors,ETC.ACETONED EMBLEMS,billet grille,Fabtech 8" all spring lift,Dual front shocks,37"Toyo M/T's,Banks Monster Exhaust,cat gone,Fumoto valve
  #18 (permalink)
Old 04-26-2007, 02:03 AM
cabinetmaker00's Avatar
cabinetmaker00 is starting off with a positive reputation.
Hey Matt would I need headstuds to run the ultra comp files and how much more power are they as say to the SC extreme file .
__________________
2006 f250 cc,sb,4x4,6.0.
zoodad,sc1805, 4 in lbss exhaust.
tint.
  #19 (permalink)
Old 04-26-2007, 08:06 AM
SR_Crewchief is starting off with a positive reputation.
I'm not Matt nor am I a Powerstroke expert, but...
If all your adding is programming then I'd have to say, no you don't need headstuds. Programming effects fueling and timing not boost. At least not directly. If you add a larger TC that segnificantly increases your boost then yes.
My diesel knowledge is limited to Cummins and even that is not expert.
__________________
1988 F150 std cab LB 4x2 300/4.9l M5OD 3.08's 288,000+ original miles.
  #20 (permalink)
Old 04-26-2007, 08:41 AM
npccpartsman's Avatar
npccpartsman is gaining momentum as a positive member of FTE.npccpartsman is gaining momentum as a positive member of FTE.
It's very "easy" to write programming for a stock motor that will require more than studs and with the VGT turbo you do control boost with programming. That's not to say that they're safe tunes though. You don't have to have studs to run any program, but if you have the means or opportunity then definitely put head studs in.
__________________
I BLEED RAZORBACK RED
  #21 (permalink)
Old 04-26-2007, 11:14 AM
FTE Sponsor
Quote:
Our Ultra Comp makes the "SC Extreme" look like a playtoy. As far as head studs are concerned; While they are not absolutely neccessary to run the file, it is more than advisable. Some trucks will handle the file just fine (a good majority) but if there are any flaws in the head seal whatsoever, rest assured the Ultra Comp will probably take them out.
__________________
Matt Geouge
  #22 (permalink)
Old 04-26-2007, 01:27 PM
Jocaren's Avatar
Jocaren is starting off with a positive reputation.
I got headstuds with mine, but im a little bit of a speed demon and terrorize everything!!! lol But like matt said that ultra comp is alot faster than a xtreme race program
__________________
06 250 4x4 CC,SCT.gauges.studs.exhaust
03 reg cab 2wd- II silver bullet 66,275cc injectors,Elite stage 3 fuel system, dual stage nitrous, suncoast by Darren Morrison, built and tuned by Eric at Innovative
  #23 (permalink)
Old 07-27-2007, 09:01 PM
boxcar_tommie22 is starting off with a positive reputation.
toyota and nissan cannot come close to our big fords...
  #24 (permalink)
Old 07-27-2007, 10:10 PM
jim6liter's Avatar
Thats the same thing I was thinking!
__________________
  #25 (permalink)
Old 07-27-2007, 11:41 PM
6L PWR's Avatar
Duct Tape Specialist
6L PWR is gaining momentum as a positive member of FTE.
Quote:
Motor Trend specs are from 2005. 2007's have more HP & Torque
2008's out next month...more HP & Torque...
I'll play!
Oh, wait, already played with a 2007 Titan. If the 2008's have even more, well, I'm still not worried.
BTW- If they're 5400lbs, then I outweigh them by over a ton!!
  #26 (permalink)
Old 07-28-2007, 09:16 AM
jdadamsjr is starting off with a positive reputation.
Quote:
Originally Posted by 6L PWR
I'll play!
That IS the point isn't it --- to Play
__________________
05 Ex 4x4 6L -Walker BTM, 9005's fogs, GOSRACING headlight wiring harness, Silverstar 9008's, SCT is all - 8.9 @ 75 1/8th!
Gone but not forgotten -2003 Ebony Ex, 4x4 6L Westin Bull Bar, PIAA 520's, PIAA Headlamp UpgradeTurbo-back Exhaust...
even goner-2002 4x2 7.3L Ex Limited-buy back
  #27 (permalink)
Old 08-08-2007, 05:39 PM
AaronC is starting off with a positive reputation.
I have a Titan SE king cab 2wd, with tow package and an AFE cold air. My buddy has a 7.3 2wd extra cab with a programmer, exhaust, cold air. Anyway we were leaving the lake, both towing our jet ski's and I had no problem putting 2 truck lengths on him with quickness. He's run 15.3 in the 1/4 mile in his truck, and I've never run mine at the track. We both raced our 5 liter mustangs together and thought what the hell with the trucks. He was very surprised what the Titan had in it. You guys might want to check out Titantalk.com as there are guys who have trucks that'll be more comparable. Once modified anything goes, so imo there's no fair ground. I know there are small shot of nitrous (50-75 hp) Titan's running well into the 13's and they respond very good to exhaust as well. A set of steeper gears would help a lot and better tires. Anyway, the thread title caught my interest and now I need to get back to looking at the 6.4 forum and see if I wanna switch trucks yet.
  #28 (permalink)
Old 08-08-2007, 11:08 PM
scottie2hottie's Avatar
scottie2hottie is gaining momentum as a positive member of FTE.
put 10k on the rear then do the quarter mile vs him and the same load
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
1994 F350 "Possum"
1982 F250 "Amos Moses"
Proud to be an OHIO BOY
  #29 (permalink)
Old 08-10-2007, 02:28 PM
bigblock_drock is starting off with a positive reputation.
hey aaron check this out. i dont know if either truck was stock but....
http://videos.streetfire.net/video/6...ae015a0cd4.htm
  #30 (permalink)
Old 08-10-2007, 03:24 PM
Why are you 6.0L guys worried anyways....???? My old bone stock (except straight pipe) 7.3L dually weighing in at nearly 8000lbs can hang with a hemi in a durango, and not get beat by more than a car length in just under a qrtr mile by a nissan. When i marked up against my buddies stock 6.0L he cleaned my ass. Stock 6.0L to stock nissan i'll bet on 6.0L(or any other gas truck for that matter IMO) modified 6.0L vs modified nissan look the hell out nissan.
__________________
1994 F350 "Possum"
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
