air bag light flashing code 47 what is wrong
Old 04-14-2007, 07:01 AM
nmcjg44's Avatar
nmcjg44
nmcjg44 is offline
air bag is flashing code 47 on ford ranger 2002 what is the problem
Old 04-15-2007, 07:38 AM
rangr's Avatar
rangr
rangr is offline
47
The passenger's side seat belt pre-tensioner showing high/low resistense.
Old 04-15-2007, 08:30 AM
nmcjg44's Avatar
nmcjg44
nmcjg44 is offline
high this under the seat correct
Old 04-15-2007, 08:32 AM
nmcjg44's Avatar
nmcjg44
nmcjg44 is offline
is this expensive to fix does it cause the airbag not to work in an accident
Old 04-15-2007, 09:33 AM
fflintstone's Avatar
fflintstone
fflintstone is offline
It better not!!!! I would think that Ford would be sticking their collective necks way out to think that a misfunctioning seat belt pretensioner would disable the airbag. The airbag light is simply flashing a code that there's a problem with the seatbelt system which is the primary restraint system. If your airbag was faulty, the appropriate code would flash, darn If I know what it would be. As for cost, at worst, you may have to replace the pretensioner, but check the electrical connections.
Old 04-15-2007, 10:56 AM
nmcjg44's Avatar
nmcjg44
nmcjg44 is offline
thanks so much is the pretensioner located at the back of the seat
sudsmcduff
06-25-2016 08:22 AM
VRC9170
11-17-2010 12:36 PM
markmartin6fan
1997 - 2003 F150
03-11-2008 11:40 AM
whruppe
Aerostar
01-16-2008 09:05 PM
knockback150
05-20-2005 12:39 AM
Quick Reply: air bag light flashing code 47 what is wrong
