2007 f150 5.4V8 Rough Idle????? - Ford Truck Enthusiasts Forums
Old 04-14-2007, 12:43 AM
mattk15 mattk15 is offline
mattk15 is starting off with a positive reputation.
I have an 07 f150 v8 5.4 and it idles very rough. When i start it it seems to start reallut it y rough and just about everytime im stopped its shaking just enough to annoy me. Do you think its the spark plugs? I took into the dealer about a month ago and they said everything was fine. But its still doing the same thing. Also the A/C tottaly sucks is that they way it is? I live in los angeles and it gets 120+ deg in the summer is there anyway to fix that? When i accelerate the cold air gets kinda warm and it doesn't get cold until i get up to speed.
Old 04-14-2007, 01:35 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
1. what is your problem? the truck has a rough idle I'm guessing.
have you ever owned a truck before? not trying to be snide, but the trucks "run" rougher. this is due to stiffer motor mounts, and less drivetrain shielding than a car.
or you could have a misfire. it's not likely though since you said the dealership already called it good...
2. your A/C is on the brink? make sure the A/C button is selected. at idle, the rpm are a little low so the compressor isn't that efficient, so it won't blow as cold, but it should blow somewhat cold. a temporary loss of cooling might occur, but should not last longer than a few seconds. try putting the cabin air on recirc. that will help the cabin air get colder quicker.
Old 04-14-2007, 02:18 AM
Yes this is my 6th ford truck, ive owned 4 superdutys and 2 f150's. I'm very experienced with these trucks and this 07 f150 deosn't feel right. And i mean the ac barely gets cold for a $45,000 truck it should get cold.
Old 04-14-2007, 03:11 AM
Tylus's Avatar
the A/C not blowing cold seems to be a problem for alot of people. wish I could help you. my truck blows freezing cold
I recommend you get back to the dealership to fix it.
Old 04-14-2007, 07:20 AM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
Quote:
Keep taking it back or go visit another dealer. My 07 has a rough idle, but haven't gone back for it to be checked out yet. My 03 did it and my wife's 04 Expy does too. Both of these were back to the dealer a few times, but it was never resolved. If the thing isn't throwing a code, tech's these days are helpless or worse, don't know how to diagnose problems like they used to....
Good luck finding the fixes to your issues. Can be frustrating with some dealers, but there are decent one's out there....
Old 04-14-2007, 11:43 AM
bridge's Avatar
bridge bridge is offline
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
The 3V 5.4L's are known for having rough idle condition. The Expy has a TSB for it but the dealers don't want to deal with it for some reason. I've had my Expy in twice with this complaint so I feel your pain. However, my Screw is yet to have this problem. As far as the AC, I've read some made it to dealer lots without the Freon level being topped off. I do have that problem. Sometimes it's ice cold and other times it's ambient temp.
Old 04-14-2007, 12:03 PM
66f25red 66f25red is offline
66f25red is starting off with a positive reputation.
Does the truck have an auxillary fan in front of the condenser? If it is so equipped, and not working as designed, the a/c can not reject the heat it picks up in the cab via the evaporator, and then as you are able to move the vehicle the air is moving across the condesor so the in cab air is colder.
Old 04-14-2007, 02:59 PM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
Well I can’t comment on the A/C, it’s still too cold around here for that. But as far as engine idle, mines silky smooth, if it wasn’t for the tach I’d think it stalled. Dealers seem to avoid work at all costs, so if it’s only a little problem they’ll feed you the “That’s the way it is” or “everything is fine” excuses. You’ll have to become very annoying for them to get anything done, that’s just been my experience in the past.
Old 04-14-2007, 03:22 PM
Do you think maybe if i put better spark plugs in it might smooth it out a little?
Old 04-14-2007, 03:47 PM
90taz 90taz is offline
90taz is starting off with a positive reputation.
deel with it, its the charicteristic's of the motor. i agree it sucks for the price we pay for the vehicle, its just something you have to live with. just keep track of how many times you you take it in and how long you are without the vehicle. you can always lemon law it
Old 04-14-2007, 08:22 PM
mcons mcons is offline
mcons is starting off with a positive reputation.
Hey Matt15, I just bought my 07 F150 and so far so good. My friend is a Ford mechanic and states that the one flaw on this truck is the fuel filter (if you could call it a flaw). Make sure to change out the fuel filter at 15K miles. This could make the idle rougher than normal. Poor quality gas can also clog up the filter earlier than 15K.
Old 04-14-2007, 08:28 PM
nascar6dude nascar6dude is offline
nascar6dude is starting off with a positive reputation.
Yours is a well documented complaint, my 4.6 idles a little rough also, seems to be a common trait of the modular engines. They SHOULD idle smoother than older models, as the motor mounts are not stiffer, but rather liquid filled, an attempt to reduce engine vibration. I suspect it's more of a fuel/air mixture issue, these motors seem to be designed to run pretty lean. And Ford service techs don't help much with their ""It's normal, they all do that" response. It being a truck has no bearing on idle quality, my old F-150 with a 302 idles much smoother than my '06. It DOES suck, but as 90taz says, it's just something we'll have to put up with.
Old 04-14-2007, 08:42 PM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Very strange...my '07 is very smooth. I can hear it, but there is no noticable vibration in the cab.
Maybe you should insist on going out to the lot to see a new truck with the same motor, show them how it vibrates less, and see what they can do about it.
Old 04-14-2007, 11:48 PM
edgl edgl is offline
edgl is starting off with a positive reputation.
I have an 06 F350 with the 5.4 engine, and it idles so well, that it is hard to tell that it is running. I have a friend who wanted to drive the truck. I had it running when he got in the drivers side, and he turned the key to start it. I told him that it was running, and he looked at the tach, and told me that he didn't realize it was running, because it was so quiet, and smooth.
Old 04-15-2007, 12:00 AM
Tylus's Avatar
a rough idle in the 5.4 is not normal. mine is so quiet that I can't tell it's running
if I let it idle for about 15 minutes (line at the bank) it will start to get the faintest rumble, but thats it.
a slightly rougher idle in the 4.6 is normal. it does it in the majority of the trucks, exploders, mustangs, and sport tracs...no one knows why, but it does
Engine Idles rough when cold !!!! Charlie2003 1999 to 2016 Super Duty 1 09-25-2015 08:02 AM
Rough Idle when Cold Charlie2003 1999 to 2016 Super Duty 0 09-22-2015 09:38 PM
5.4, 3 valve.. Rough idle Milly1219 2004 - 2008 F150 0 06-11-2014 10:48 PM
rough idle rbell0 2004 - 2008 F150 3 07-04-2012 05:50 PM
2001 5.4 250 SD Rough Idle magikal_dragons 1999 to 2016 Super Duty 17 02-11-2011 04:04 AM
Tags
06, 07, 2006, 2007, 2008, 54, 54l, common, f150, ford, idle, low, rough, v8, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
