Home-Made Bumper
Home-Made Bumper
I made a bumper for my truck Monday and Tuesday after being pissed off for so long about not having any two points up front. I debated long and hard about whether or not to build it arounda winch of my choice...but I decided instead to just include a front reciever in it and then I could buy a winch later to use with the reciever and keep it in my toolbox. My design is pretty similar to Josh88Ford's, but simpler and not quite as aesthetically pleasing. I spent about twenty hours at my dad's metal shop building it with the help of some guys that work with him. Without the expensive equipment, it would have taken twice as long.
Here is my stock bumper, which is shimmed out about two inches temporarily with some brackets I had a buddy fab up. It is slightly twisted and has a small dent or two in the middle. Worst of all, it has NO tow points.
Here is my new bumper about halfway through the build-up. I used a piece of 3/8" thick 8" C channel with a 2.5" flange. We marked points under the grille to bend the C channel back to follow the lines of the truck. The bend of the bumper was about 20 degrees. We cut the flange and bent it by hand while it was hot, then welded the flanges back up. My dad just happened to have a whole Class III hitch lying around to which it fit we did not know. Because of this I was given permission to chop it up and use it for my bumper. I used a flame table to cut the shackle mounts out of 3/8" steel plate. I just drew a template and bam it was cut.
This is the final product. After tons of fitting I measured for a top plate to cover the gap between the top flange and the grill, and cut it out of a large sheet of steel diamond plate. A good spot was marked to cut the ends of the bumper, and each end was capped with 3/8" plate. We made a small push bar with more 3/8" plate and 1 5/8" tubing. Because of the little distance the bumper sticks out from the grille the push bar is flush with the front of the c channel. Also there is no more than 1/2" between the 3/8" plate and the grill. However, the push bar is really only for looks, unlike the bumper. I spray the whole bumper with a rattle can once, then spray the front once after it was mounted. This weekend I will most likely spray the whole bumper once more with it off the truck. I have 5/8" shackles on there now, but I need 3/4" or 7/8" because my mounting hole is 1", and they slop around more than I would like.
Yeah in the last pic I had not put my shackles on yet and my lights were not mounted...just sitting where I was thinking abotu mounting them. The picture with the shackles on the bumper is where I mounted the lights. If and when I do get a winch I will have to wire up the front hitch. I don't have a picture quartering away but in a couple minutes I'll run outside and take one...
man that is sweet, i have been thinking of doing something like that with a hitch and shackles. I work for a steel distributor so i can get the steel for the complete setup cheaper than a new bumper, and it is 10 times more useful. gonna make something similiar for my rear bumper also. nice work. thanks for the picks, i'm gonna just rip off your idea for my 89. Dan
