6.4l fuel economy
#31
Originally Posted by Banksstroker
Florida Chris,
I had a 1999 7.3 L and always towed the same boat at +-79mph and got between 11-14. I also went at the same speed with this truck to Miami when it was brand new and got between 11 and 14 unloaded. I was hoping to get comparable to my 7.3L, hoping....preferably above 10 MPG. And after checking, I believe my boat is between 2000-3000lbs, not 3-4K.
Banksstroker
Banksstroker
#34
Originally Posted by firehawk198
kimminau, got ya, I'll get it on the turnpike tonight to get the rpms for you. real good idea to change the tire size to get the gearing up. Orig on my 99 looked to do the opposite. Was going to put tires on to get the same results of going fro 3.73 to 4.10s. just couldn't get the load range at the time.
#35
#36
kimminau, finally took it on the turpike last night. here is the breakdown as close as I could figure. rpms could be off .25 to .50. The one you were looking for 75mph was 2400 rpms. here is the breakdown. 55@1750, 60@1925, 65@2075, 70@2250, 75@2400, 80@2600, 82@2750. could not believe how stable it was at 82 felt like it could have gone a 100 easy but that speed governor sure kicked in. pulling our camper I usually had to run about 72mph in my 99 to keep it in the torque range of the v10. plan to run at 65(speed limit) with the 450. not sure in the tow mode if it will still just run 2075@65 or if the computer will kick up the rpms, probably depends on the hills. Had my first fill today 30.37 gallons @ 360 miles. computer showed 12.4mpg calculator 11.85 mpg round town and rural. of course 82mph last night for a bit probably did not help( but it felt good)
#37
#38
#39
I just filled up with just under 1/2 tank left and 254 miles on odometer and it took 17 gals to fill up for about 14.94 mpg (calculated, computer said 14.3). It was about 65% hwy and 35% city, so my mileage is getting better. I have about 1350 miles on the silver beast and loving her still!
#40
#41
I have an 08 F-250 Crew Cab 4X4 Long bed with almost 2,000 miles on it. I drive about 1/2 freeway and city and the best MPG I've got is 12.5 The computer has never shown higher than 10.5. And, I'm not even pulling anything either. Although in Socal its hard to cruise at 65 mph on a freeway for very long.
#42
Actually, I think I am going to hold off a little while before doing anything. I have about 5,500 miles on her now and my mpg just keeps creeping up. When I first started towing with her I was at +/-6.5 mpg, actually towing heavier loads now over the same roads and I am getting pretty close to 9 mpg right now.
#43
I drive a diesel near everyday so I am hard to fool when it comes to MPG. I do have a 05 gasser now because I would not buy the 6.0L, my choice.. I am considering the 6.4l . My truck is a work truck its work is pulling a near 13K 5th wheel all over the country.We are not all that concerned with MPG but as I read these post I see numbers all over the place and I wonder??? Most folks i know that pull in that weight range average @ 9 to 12 Diesel.. I get 7.5 to 10 with the V-10 .Now someone will post they get 15/16...right... There are two areas that folks have a hard time with the truth..when they are doing their taxes..and when they are telling about their MPG.
#44
#45
